qtdragon - new tool length after a manual tool change
5 years 10 months ago #191892 by seebaer1976
cmorley wrote: This is qtvcp's other probe screen.
How can I switch the probe screen from Basic Probe to Versa Probe?
would like to try Versa Probe, maybe I can do it with it.
best regards
seebaer1976
5 years 10 months ago #192228 by hottabich
4 years 11 months ago #226091 by ikkuh
Is this still a work in progress?
Using the latest version that is bundled with the BuildBot 2.9pre version (I update daily) there now is a pop-up screen but no movement to toolsensor or even toolheight measurement.
What am I doing wrong? I expected the behaviour to be like gmoccapy's toolmeasurement, the remapping of M6.
4 years 11 months ago #226261 by cmorley
Unless you added remap code to your configuration, then it will not probe at tool change.
I had done some work on a (hopefully) standard remap code to cover most requirements, but have not finished it.
but what ever code that was used with gmocccapy should be able to be adapted to qtdragon.
4 years 11 months ago #226516 by harry4516
I'm using qtdragon,
just implemented the files from Peter, talla83, video #29
and I can confirm that it works perfectly. Almost all setup was done with pncconf, then I added Peter's extensions.
During the first test the Z movement stopped with an error msg at the tool probe. This was fixed
by debouncing the tool probe.
When M6T1 is in the gcode, it moves to the tool change position, I change the tool and click the confirmation dialog. Then it moves over the tool sensor and slowly touches it. Then it moves z up to a secure position and continues.
4 years 11 months ago #226602 by hottabich
Hello Harry. Would you like to share your settings? Here's another option, can anyone try it: wiki.printnc.info/en/controllers/linuxcnc/tool-setter-no-probe
Time to create page: 0.314 seconds
