qtdragon - new tool length after a manual tool change
6 years 4 months ago #173323 by seebaer1976
I got in touch with peter dam ... from talla83.de. last year he wrote a script for dynamic tool measurement.
asked him if you can install it in qtdragon.
he has agreed and approved to use it.
here is a video on youtube:
and here the script:
File Name: WZ-PROBE.zip
File Size:1.22 KB
Maybe it will help you.
it can perhaps be so integrated that it can be activated or deactivated under settings for those who do not need it.
markus
6 years 3 months ago #173369 by cmorley
So now that we know it's a remapped tool change that adds probing - It's not a qtdragon issue it's a configuration option.
If it's common enough I suppose I could add an example config - the problem being that the complicated sample configs often don't work if you move them because file path references (of macros for instance) are not very flexible to change
Chris
6 years 3 months ago #173591 by seebaer1976
Would it be a lot of work to incorporate your own macro, what does this measure after the tool change?
maybe you can integrate it so that you can activate or deactivate it when you don't need it.
6 years 3 months ago #173618 by cmorley
Those macros included in qtvcp are primarily to probe work pieces for a mill.
Remapping tool changes is a different configuration process - not related to screen files.
So there is nothing to incorporate into qtvcp, you must remap toolchanges with INI changes and python remap files.
I don't think there are any samples in the official docs - probably would be a good project to include.
The following user(s) said Thank You: tommylight, seebaer1976
6 years 3 months ago #173869 by seebaer1976
would declare myself ready to test when the time comes.
unfortunately i have no idea about python, i'm learning it.
markus
6 years 3 months ago - 6 years 3 months ago #175463 by hottabich
Notice the modified version of Qtdragon. There it is possible to use the WZ-Probe macro. forum.linuxcnc.org/qtvcp/38247-sample-qt...eens?start=30#168892 If you are interested, I have a version with the latest changes.
Last edit: 6 years 3 months ago by hottabich.
Time to create page: 0.061 seconds
