qtdragon tool table issues
- keyboard
- Thank you received: 4
16 Oct 2020 01:49 #186243
by keyboard
Replied by keyboard on topic qtdragon tool table issues
Here they come..
- hottabich
- Thank you received: 96
16 Oct 2020 07:26 #186257
by hottabich
Where do the degrees on the three axes come from?
Replied by hottabich on topic qtdragon tool table issues
Here they come..
INCREMENTS = JOG, 1.0mm, 0.1mm, 0.01mm, 90.0 °Please Log in or Create an account to join the conversation.
- Thank you received: 2181
16 Oct 2020 09:31 #186267
Replied by cmorley on topic qtdragon tool table issues
Yes I think that is the trouble...'jog' and the degree sign probably break qtvcp jog selection. I'll look at the code and see if I can make it behave better.
I assume those settings are used by something else?
- keyboard
16 Oct 2020 11:51 #186275
by keyboard
The degrees, were there before, and I left them in, for the 4th axis I plan for future. I will take it out , if it will correct it for now ands try..
Thanks.
Thanks.
- lllars
- Thank you received: 3
18 Oct 2020 16:19 #186474
by lllars
Replied by lllars on topic qtdragon tool table issues
Finally getting around to testing these fixes... Seems to be working perfectly so far. I can enter negative values and I'm not getting any tool wear entries. Thanks Chris!
- keyboard
18 Oct 2020 19:30 #186487
by keyboard
Can you guide me how to update these fixes. thanks
- lllars
18 Oct 2020 19:45 #186491
by lllars
All I had to do was run in a terminal:
That installed the latest version of linuxcnc-uspace, along with a bunch of other unrelated updates. I did not have to modify any config files or do anything else.
Note that you'll need to be on the master version of linuxcnc for that to work. I.e. something like this in your /etc/apt/sources.list:
sudo apt-get update
sudo apt-get upgradeThat installed the latest version of linuxcnc-uspace, along with a bunch of other unrelated updates. I did not have to modify any config files or do anything else.
deb http://buildbot.linuxcnc.org/ stretch 2.8-rtpreemptPlease Log in or Create an account to join the conversation.
- keyboard
18 Oct 2020 21:12 #186513
by keyboard
Thanks for the quick reply.
I could not update, even after making the repository changes.
my version is LINUXCNC - 2.9.0-pre0-2780-g9f6930741
I get the following:
Hit:1 xhttp://deb.debian.org/debian buster InRelease
Hit:2 xhttp://security.debian.org/debian-security buster/updates InRelease
Hit:3 xhttp://deb.debian.org/debian buster-updates InRelease
Get:4 xhttp://linuxcnc.org buster InRelease [28.5 kB]
Err:4 xhttp://linuxcnc.org buster InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 3CB9FD148F374FEF
Reading package lists... Done
W: GPG error: linuxcnc.org buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 3CB9FD148F374FEF
E: The repository 'linuxcnc.org buster InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: Target Sources (base/source/Sources) is configured multiple times in /etc/apt/sources.list:25 and /etc/apt/sources.list:27
- lllars
18 Oct 2020 21:15 #186514
by lllars
See the linuxcnc buildbot page. It explains how to set up repositories and get keys.
- keyboard
18 Oct 2020 21:52 #186519
by keyboard
Thanks again. Thats where i 've been , but a dead end.
Time to create page: 0.158 seconds
