DEFAULT Resources.py file needs to be compiled at: /usr/share/qtvcp/screens/qtdragon/resources.py (qt_pstat.py:216)
Unable to open /usr/share/qtvcp/screens/qtdragon/resources.py for writing
One problem is that user pi can't write to that directory without root privilege. It should be writing to the config directory.
Regardless, it won't work anyway if you want a graphics display. The Rpi uses OpenGL ES and qtvcp uses OpenGL. They are incompatible. I did manage to create a version that uses VTK but it's untested and not yet posted to github. I think one of the other GUIs, like Axis, might run OK, never checked. I would like to run my machine with a pi as well but not having much luck getting the graphics to work.
I should clarify. Linuxcnc works fine on the pi, it's QtDragon with the qt5_graphics library that doesn't.
