On Screen Keyboard Display Issue
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
30 Oct 2020 02:01 #187756 by phillc54
On Screen Keyboard Display Issue was created by phillc54
#1. Using the onscreen keyboard for MDI shows up some odd but consistant behaviour:
Warning: Spoiler!
#2. Is it possible to style the onscreen keyboard or use an overlay with it?
#3. I have been able to customize most of the GcodeDisplay/GcodeEditor to suit what I want but I am having a devil of a time with the fonts. I can change the font color/size on the margin and the body at initialisation. As soon as a file is loaded then the size reverts to some default value. I can then change the margin font color dynamically but not the body font color. Any suggestions?
30 Oct 2020 03:47 #187759 by Grotius
Replied by Grotius on topic On Screen Keyboard Display Issue
Hi Phill,
Maybe it has to do with anchor position, This property was introduced in QtQuick.VirtualKeyboard 2.2.
doc.qt.io/qt-5/qml-qtquick-virtualkeyboa...#anchorPosition-prop
doc.qt.io/qt-5/qtquick-positioning-anchors.html
  • phillc54
  • Platinum Member
  • Platinum Member
30 Oct 2020 04:45 #187763 by phillc54
Replied by phillc54 on topic On Screen Keyboard Display Issue
Hi Phill,
I don't even know what qtquick is. So far I have found qt a real rabbit hole but I have so much time invested in it that I need to keep going.
30 Oct 2020 06:36 #187785 by cmorley
Replied by cmorley on topic On Screen Keyboard Display Issue
The softimputwidget does have code for positioning the window when displayed - ill have to dig into that.
This soft input widget was built early in the project and maybe using a regular qtvcp dialog (that can remember position) would be better.
this is the stock style of the softinputwidget )it's a Qdialog):
SoftInputWidget {
font-weight: bold;
color: #333;
border: 2px solid #555;
border-radius: 15px;
padding: px;
background: qradialgradient(cx: 0.3, cy: -0.4,
fx: 0.3, fy: -0.4,
radius: 1.35, stop: 0 #fff, stop: 1 #888);
min-width: 30px;
there is also style for the pushbuttons:
MyFlatPushButton {
font-weight: bold;
color: #333;
border-radius: 11px;
padding: px;
fx: 0.3, fy: -0.4,
min-width: 30px;
Hopefully that is helpful.
I'll have to look into the font problem. the editor is certainly a pain style wise.
Chris
  • phillc54
  • Platinum Member
  • Platinum Member
30 Oct 2020 06:48 #187786 by phillc54
Yeah it is really odd, there are two other permutations of thisGUI where it woks perfectly well. They have the MDI widget on the left side of the GUI. If it is too difficult I can move the GcodeDisplay widget to the the right hand side.
SoftInputWidget {
font-weight: bold;
color: #333;
padding: px;
fx: 0.3, fy: -0.4,
min-width: 30px;
MyFlatPushButton {
font-weight: bold;
color: #333;
padding: px;
fx: 0.3, fy: -0.4,
min-width: 30px;
Thanks, I'll have a play in the morning.
Yep, you are not wrong there. :)
30 Oct 2020 07:21 - 30 Oct 2020 07:34 #187789 by Grotius
Hi Chris,
For info, gscreen has a infinit terminal output if i start it with a rip install :
spindle bar err-->>> No widget 's_display2'
Phill,
If you share your current source code, i can simulate your problem, and maybe help a bit.
Last edit: 30 Oct 2020 07:34 by Grotius.
30 Oct 2020 07:53 #187790 by cmorley
fixed
  • phillc54
  • Platinum Member
  • Platinum Member
31 Oct 2020 02:39 #187865 by phillc54
Doh, I just worked out that the onscreen keyboard is entry_widget.py :blush:
I have put it on Github if you want to take a look.
github.com/phillc54/qtplasmac
31 Oct 2020 23:59 #187988 by cmorley
What code did you use to change the font on initialization?
01 Nov 2020 00:56 #187991 by Grotius
Hi Phill,
I submitted a little issue on github. Have a look. I would like to test your version today !
Time to create page: 0.284 seconds
