On Screen Keyboard Display Issue
- phillc54
- Thank you received: 2100
01 Nov 2020 06:39 - 01 Nov 2020 07:21 #187992
by phillc54
I tried:
self.w.gcode_display.setMarginsFont(font)
and:
text = bytearray(str.encode('Arial'))
self.w.gcode_display.SendScintilla(QsciScintilla.SCI_STYLESETFONT, QsciScintilla.STYLE_DEFAULT, text)
But they are now commented out and I cannot remember which one worked. As soon as a file was loaded it reverted to the original default.
Edit: added text = code that I forgot earlier...
Edit2: This worked:
Replied by phillc54 on topic On Screen Keyboard Display Issue
What code did you use to change the font on initialization?
and:
Edit2: This worked:
font = QtGui.QFont()
font.setFamily('Lato')
font.setFixedPitch(False)
font.setPointSize(24)
font.setBold(False)
self.w.gcode_display.setMarginsFont(font)As soon as a file was loaded it reverted to the original default.
Last edit: 01 Nov 2020 07:21 by phillc54.
- phillc54
01 Nov 2020 07:12 #187993
by phillc54
I can load it on a buster rip master branch and a buster local master branch installation.
There is a path issue with 2.8 branch that affects the sim panel so I moved some files and it also works on stretch for rip and local.
Hi Phill,
I submitted a little issue on github. Have a look. I would like to test your version today !
- Thank you received: 2181
02 Nov 2020 07:36 #188090
Replied by cmorley on topic On Screen Keyboard Display Issue
It seems fonts are much more complicated then i may first seem.
There are default fonts, default lexer font and individual lexer style fonts.
For now try this:
I'll need to add convience method to make this easier in the future.
Chris
For now try this:
self.font = QFont()
self.font.setFamily('Lato')
self.font.setFixedPitch(True)
self.font.setPointSize(10)
self.w.gcode_editor.editor.font = self.font
for i in range(0,4):
self.w.gcode_editor.editor.lexer.setFont(self.font,i)
self.w.gcode_editor.editor.set_background_color('#FFFFFF')I'll need to add convience method to make this easier in the future.
Chris
- phillc54
03 Nov 2020 22:50 - 03 Nov 2020 22:51 #188278
by phillc54
Edit: It worked in a GcodeDisplay as well.
Sorry, I forgot to give this a try yesterday. I quick tryout this morning and it looks good, Thank you.It seems fonts are much more complicated then i may first seem.
Last edit: 03 Nov 2020 22:51 by phillc54.
08 Nov 2020 02:36 #188639
i add the ability to set background color, lexer text colors. lexer text fonts with stylesheets in master. There are basic docs about it under 'qtvcp widgets'
Hopefully they are useful to you as you can change the colors that work with the rest of the screens colors.
Chris
Chris
The following user(s) said Thank You: phillc54, Himarc3D
- phillc54
08 Nov 2020 02:52 #188640
by phillc54
Cool, I'll take a peek . I have just about finished the color changing stuff
- JohnnyCNC
- Thank you received: 115
08 Nov 2020 03:00 #188641
by JohnnyCNC
Replied by JohnnyCNC on topic On Screen Keyboard Display Issue
I was just looking for virtual keyboard. I'll be watching this with great interest. Thank You.
08 Nov 2020 03:18 #188642
JonnyCNC
based on your other post I think you are looking for a virtual keyboard for the system rather then the screen.
matchbox and onscreen keyboard are system widget virtual keyboards.
Thew virtual keyboard in wtvcp only works for the qtvcp screen.
Chris
Chris
- JohnnyCNC
08 Nov 2020 03:47 #188645
by JohnnyCNC
Thanks Chris,
I mainly want it for doing MDI keyins or offset values and the like while I am in QTDragon. I did install the virtual keyboard "Florence" and it does work but what was shown here looks much more conveniant to use while in QTDragon. If I am doing other stuff I'll just use my physical keyboard and mouse.
08 Nov 2020 17:23 #188675
JohnnyCNC
QtDragon has a builtin keyboard for MDI and offsets. should be a button on the top right of the tabs - 'KEYBD"
Chris
Chris
Time to create page: 0.203 seconds
