FileManager extensions
- phillc54
- Thank you received: 2100
18 Nov 2020 02:28 #189637
by phillc54
FileManager extensions was created by phillc54
In my ini file I have:
Printing INFO.PROGAM_FILTERS_EXTENSIONS shows:
When using FileManager to open files the extensions are used individually, Is it possible to use them simultaneously, with the exception of "all files"
[FILTER]
PROGRAM_EXTENSION = .nc,.tap remove z axis stuffPrinting INFO.PROGAM_FILTERS_EXTENSIONS shows:
['*.ngc', '*.nc', '*.tap', '*']When using FileManager to open files the extensions are used individually, Is it possible to use them simultaneously, with the exception of "all files"
- Thank you received: 2173
18 Nov 2020 02:36 #189638
Replied by cmorley on topic FileManager extensions
This is something i have been just working on.
The file dialog works as you want so it is possible.
it wasn't clear to ma at the time how to apply multiple filters simultaneously.
So short answer no but hopefully in the soonish future.
Chris
Chris
- phillc54
18 Nov 2020 02:41 #189639
by phillc54
Replied by phillc54 on topic FileManager extensions
Great, thanks Chris.
Another thing, when I go to Edit Mode the New, Open and Save buttons don't appear to do anything. I guess I am missing something.
18 Nov 2020 02:53 #189640
Do you have the 'file dialog' option turned on in the screenoption widget?
And yes it does look like the new button doesn't clear the text as it should - i'll fix that.
- phillc54
18 Nov 2020 03:00 #189641
by phillc54
Oops.
Last question today. When a file is opened and run through a filter then a temp file is created and opened by LinuxCNC. Is the original filename available somewhere?
18 Nov 2020 03:12 #189642
try ACTION.prefilter_path
It should hold the last loaded file name as a string.
- phillc54
18 Nov 2020 03:15 #189643
by phillc54
Thank you, that works a treat.
19 Nov 2020 07:05 #189760
ok I pushed an upgrade so extensions work properly in file_manager
Chris
Chris
- phillc54
19 Nov 2020 07:55 #189762
by phillc54
Great, thanks again Chris.
- phillc54
20 Nov 2020 00:03 #189845
by phillc54
Time to create page: 0.430 seconds
