Update 2.8.0 to 2.8.1 with qtvcp issue
16 Dec 2020 11:19 #192144 by partec
at the Update 2.8.0 to 2.8.1 - only to try it - following qtvcp issue
/home/user/linuxcnc/configs/sim.axis.qtvcp/
*.INI
EMBED_TAB_NAME= qtscreen
EMBED_TAB_COMMAND= halcmd loadusr -Wn qtvcp_embed qtvcp -d -c qtvcp_embed -x {XID} cam_align
File "/home/user/linuxcnc/configs/sim.axis.qtvcp/cam_align_handler.py", line 94, in nextFrame
self.pin_.set(360 - self.w.camview.rotation)
AttributeError: HandlerClass instance has no attribute 'pin_'
16 Dec 2020 11:28 #192145 by cmorley
Replied by cmorley on topic Update 2.8.0 to 2.8.1 with qtvcp issue
are you using a custom cam_align handler ?
The following user(s) said Thank You: partec
16 Dec 2020 11:39 #192149 by partec
Replied by partec on topic Update 2.8.0 to 2.8.1 with qtvcp issue
thanks, the message comes in the original configuration, strange
16 Dec 2020 12:34 #192153 by partec
Chris,
I quickly reinstalled from the CD, then in 2.8.0 started qtdefault_mm and Cam View worked perfectly,
then dist-upgrade done directly, then qtdefault_mm started and Cam View no longer works
16 Dec 2020 12:45 #192154 by partec
but - interestingly - sim.axis.qtvcp with qtvcp_tab works now exactly as requested
16 Dec 2020 17:29 #192210 by cmorley
It must be pulling out a custom handler file somehow - as none of the branches have 94 lines
nor self.pin_.set
17 Dec 2020 06:12 #192242 by partec
for quick and easy customization of the QTvcp Cam View Dialog it would be good if somewhere be set
self.w.camview.diameter = 400
17 Dec 2020 17:31 #192283 by cmorley
you can.
copy the cam_align_handler.py into your configuration folder (same name)
Modify that file as you like.
Qtvcp will use the local file in your config folder.
19 Dec 2020 07:50 #192454 by partec
Chris, I would like to confirm again, as further up in the log, I installed from the Buster CD 2.8.0 on different motherboards several times and started qtdefault_mm with Cam View working perfectly, then always after dist-upgrade 2.8.1 qtdefault_mm where Cam View no longer works
19 Dec 2020 13:43 #192474 by cmorley
Thanks for putting the effort into checking different versions.
On a system that fails, could you run linuxcnc from a terminal and post all the debug messages here?
Chris
Time to create page: 1.462 seconds
