Update 2.8.0 to 2.8.1 with qtvcp issue
- partec
- Thank you received: 27
19 Dec 2020 14:14 - 19 Dec 2020 14:38 #192475
by partec
Replied by partec on topic Update 2.8.0 to 2.8.1 with qtvcp issue
in Terminal LINUXCNC - 2.8.1 in qtdefault_mm Cam View does not show anything
Last edit: 19 Dec 2020 14:38 by partec.
- Thank you received: 2181
19 Dec 2020 16:56 #192486
Replied by cmorley on topic Update 2.8.0 to 2.8.1 with qtvcp issue
I think I figured it out - thanks for the debug text.
Maybe toy would be willing to test a temparay fix on your system?
look in :
/usr/lib/python2.7/dist-packages/qtvcp/widgets
open camview_widget.py in a text editor (probably need to be sudo)
find this line:
change it to:
and save it.
Try running linuxcnc again.
look in :
find this line:
def hal_init(self):change it to:
def _hal_init(self):and save it.
The following user(s) said Thank You: partec
- partec
19 Dec 2020 21:34 #192501
by partec
thank you, Chris, found it, changed it and now it works perfectly!
Peter
Peter
19 Dec 2020 21:51 #192502
ok I pushed the fix so next update - it will be official.
Thanks for the help1
The following user(s) said Thank You: tommylight, partec
Time to create page: 1.090 seconds
