ESTOP button behavior
- Thank you received: 4153
Daang! thats right neither of you live in the southern hemisphere! I'll have to fix it myself!
- Thank you received: 1480
- Thank you received: 2181
I just wanted to see if you've had a chance to delve into the hardware handshake, etc. at all. Also see if there's anything you need from me/something I might test for you?
Can you show me how your pins are connected - or maybe your HAL files?
iocontrol.0.emc-enable-in
iocontrol.0.user-enable-out
iocontrol.0.user-request-enable
- snowgoer540
- Thank you received: 907
Sure (it's the direct output from pncconf):
# --- ESTOP-EXT ---
net estop-ext <= hm2_5i25.0.7i76.0.0.input-00
# ---estop signals---
net estop-ext => iocontrol.0.emc-enable-inHAL file attached in case you need it
- snowgoer540
When clicking a line in the preview, the Gcode always highlights 1 line ahead of the actual move. I am not sure if that's a qtvcp thing, or? But it seems off nonetheless.
Mostly because AXIS behavior is not really how linuxcnc was meant to work IMO.
Never the less trying to get the same behavior has been a bit allusive...
Preview line yes Phill told me -Qtvcp problem.
Getting the clic-gcode-line-see-it-in-the-display problem is being a pain mostly because of the same first problem.
Thanks for the report.
- snowgoer540
I think my real vote would be no GUI ESTOP at all, but it seems people here really seem to want it.the estop problem is being difficult.
Curious, how would you expect it to behave?
Shoot, sorry to double report. My fault.
Of course you can remove it if you don't want it.
Linuxcnc has an estop output pin, it should be AND with the external estop input and an external estop chain. then the button works fine.
Axis uses a button that acts like a toggle switch and a momentary switch at the same time. The button look follows the estop state of linuxcnc but you can still push it when it's down and it will stay down if state doesn't change.
And in this case you can ignore the estop out process
I have to make some custom bitton behavior in QT to make this work the same. I'm confident I can do it just takes some research.
- snowgoer540
I'd rather not remove it from my setup as every update to QTPlasmaC would be in conflict. At any rate, when it's the Axis way, it's really a non-issue as the physical estop takes charge. I never have to touch the GUI one.
I do appreciate the effort, and I'm sure the Axis folks appreciate you carrying their legacy
How broken is it? They often just need to be forced to turn a bit to clear a jam, then they work fine again. Might need to pull out any foreign objects too.
Nah it was tripping breakers and I could turn it by hand. It has gone to the dump to be replaced by a stainless steel version which hopefully won't rust out.
