Error on startup
- dgarrett
- Thank you received: 297
11 Jan 2021 16:59 #194979
by dgarrett
Replied by dgarrett on topic Error on startup
Pins like ini.z.max_limit,ini.z.min_limit are created by
task (typ: [EMCTASK]TASK=milltask)
Ref: linuxcnc.org/docs/2.8/html/man/man1/milltask.1.html
NOTES
The inihal pins cannot be linked or set in a halfile that is
specified by an inifile [HAL]HALFILE item because they are
not created until milltask is started. The inihal pin values
can be altered by independent halcmd programs specified by
[APPLICATION]APP items or by GUIs that support a
[HAL]POSTGUI_HALFILE.
...Ref: linuxcnc.org/docs/2.8/html/man/man1/milltask.1.html
The following user(s) said Thank You: phillc54, snowgoer540
- phillc54
- Thank you received: 2100
11 Jan 2021 17:00 #194980
by phillc54
I would have expected the opposite.
In your real table you are using the pmx485 userspace component and in you sim you wouldn't be. I was just thinking that the USRMOT error could be from the pmx485 component.
Replied by phillc54 on topic Error on startup
I've only seen it in SIM not in a live table, so it could be a timing thing.
- snowgoer540
- Thank you received: 907
11 Jan 2021 17:28 #194983
by snowgoer540
I’ve seen all of this before.... but like I say mostly in sim. I think I’ve seen it at the table once maybe twice
Replied by snowgoer540 on topic Error on startup
I have not seen that error before.
ini.z.max_limit is netted by the handler file as the fourth command of the initialized function. Quick testing has shown that there is no difference whether it is the first or last command.
If I rename it to the wrong pin number then I get the following:but I dont see these messages which are in the first post.<commandline>:0: Pin 'ini.z.max_limits' does not exist <commandline>:0: Pin 'ini.z.min_limits' does not existor further down:USRMOT: ERROR: command timeout emcMotionInit: emcTrajInit failedwaiting for component 'inihal' to become ready......
- AgentWD40
- Thank you received: 96
19 Jan 2022 19:20 #232493
by AgentWD40
Replied by AgentWD40 on topic Error on startup
I ran apt-get update and upgrade on my laptop today and I get startup errors now too. This is in a qtplasmac sim config.I actually get two different error messages. I've attached both for review.
- phillc54
19 Jan 2022 23:15 #232497
by phillc54
I just did the same update procedure here on an old Buster VM and it has no issues.
Can you post the resulting files from the following commands in a terminal:
apt search python3-pyqt5 > apt-search-pyqt5.txt
apt search libqscintilla2-qt5 > apt-search-qsci.txtPlease Log in or Create an account to join the conversation.
- AgentWD40
20 Jan 2022 07:41 - 20 Jan 2022 07:49 #232523
by AgentWD40
Here you go
Thinking I need to downgrade pyqt5?
Last edit: 20 Jan 2022 07:49 by AgentWD40.
- phillc54
20 Jan 2022 16:33 #232560
by phillc54
That was a thought but my versions here are identical. I am at a loss ...
It may be worth an ask in the QtVCP section of the forum.
forum.linuxcnc.org/qtvcp
- Thank you received: 2181
20 Jan 2022 17:01 #232567
Replied by cmorley on topic Error on startup
No need I see it here. I am off to work but will give some thought to this.
What version of linux are you using?
- phillc54
20 Jan 2022 17:36 #232579
by phillc54
I don't see it on either:
Debian 10:
python3-pyqt5 5.11.3+dfsg-1+b3
libqscintilla2-qt5-13 2.10.4+dfsg-2.1
MX-Linux 21 (Debian 11 spinoff)
python3-pyqt5 5.15.2+dfsg-3
libqscintilla2-qt5-15 2.11.6+dfsg-2
Debian 10:
- AgentWD40
20 Jan 2022 17:51 #232580
by AgentWD40
This is MX Linux 19.4 per the recommendation of the guide that's floating around. I may upgrade/change anyway, I'm having other unrelated issues with this distro.
Time to create page: 0.146 seconds
