Error on startup
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
10 Jan 2021 10:02 #194735 by snowgoer540
Error on startup was created by snowgoer540
I moved this from a topic under PlasmaC as there were two separate errors being posted at the same time and I didnt want it to go missed.
After updating yesterday evening, I started randomly getting this error on startup:
File "/home/plasma/linuxcnc-dev/lib/python/qtvcp/widgets/system_tool_button.py", line 106, in _set_user_system_text
self.setText(convert[int(data)])
KeyError: 0
Here is the terminal info from when it happens:
I am unsure what the cause is, or if it's a QTVCP problem, but as it pointed to a QTVCP widget, I figured I'd point it out here. Apologies if it was already reported. I do believe user robertspark also saw it forum.linuxcnc.org/plasmac/38521-gui-for...mac?start=150#194659
But for me, it is definitely the #1 error message when it happens.
Thanks!
10 Jan 2021 10:21 #194739 by cmorley
Replied by cmorley on topic Error on startup
The error message is a red herring, unfortunately.
This is not a consistent error on start up?
Isee lts of error messages from the Motion component indicating something is hanging early in the process.
you running 2.8 or master?
10 Jan 2021 10:23 #194740 by cmorley
oh I can see your using master.
I get this when switching to conversational tab (in sim)
[QTvcp][CRITICAL]  Aborted from Error Dialog
 Qtvcp encountered an error.  The following information may be useful in troubleshooting:
LinuxCNC Version  : 2.9.0~pre0
  File "/home/chris/emc/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 1195, in <lambda>
    self.w.main_tab_widget.currentChanged.connect(lambda w:self.main_tab_changed(w))
  File "/home/chris/emc/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 979, in main_tab_changed
    self.conv_setup()
  File "/home/chris/emc/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 2698, in conv_setup
    self.conv_shape_request('conv_line', CONVLINE, True)
  File "/home/chris/emc/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 2792, in conv_shape_request
    reload(module)
NameError: name 'reload' is not defined
  • snowgoer540
  • Moderator
  • Moderator
10 Jan 2021 13:10 #194752 by snowgoer540
Replied by snowgoer540 on topic Error on startup
red herring? new term for me haha
Yea, master as you saw.
I dont see that particular error. Are you using buildbot or RIP?
10 Jan 2021 14:30 #194771 by cmorley
RIP
You could try running qtvcp with -v (in the INI) to see if it gives any more info.
  • snowgoer540
  • Moderator
  • Moderator
10 Jan 2021 15:36 #194783 by snowgoer540
Interesting, They should work, Might want to get Phill to take a peek at them.
I added -v in the event it happens again, maybe I can provide additional info. I've only seen it in SIM not in a live table, so it could be a timing thing.
11 Jan 2021 07:10 #194897 by andypugh
Replied by andypugh on topic Error on startup
I think that "ini.z.maxlimit does not exist" is probably the real problem.
At a guess a HAL file is referencing those pins before the module that creates them is loaded. I am not sure which module creates them, though. I would have guessed motion, but they are not in the manpage
  • snowgoer540
  • Moderator
  • Moderator
11 Jan 2021 08:44 #194913 by snowgoer540
I think that's a fairly accurate guess. the maxlimit errors mostly shows up in SIM, but I have seen it once or twice on a live table. It always felt like a timing thing, so maybe we need to delve a little deeper into the order the modules are loaded.
11 Jan 2021 16:35 #194971 by phillc54
Replied by phillc54 on topic Error on startup
I have not seen that error before.
ini.z.max_limit is netted by the handler file as the fourth command of the initialized function. Quick testing has shown that there is no difference whether it is the first or last command.
If I rename it to the wrong pin number then I get the following:
<commandline>:0: Pin 'ini.z.max_limits' does not exist
<commandline>:0: Pin 'ini.z.min_limits' does not exist
but I dont see these messages which are in the first post.
USRMOT: ERROR: command timeout
emcMotionInit: emcTrajInit failed
or further down:
waiting for component 'inihal' to become ready......
11 Jan 2021 16:48 #194973 by phillc54
A bit more testing:
In the ini file, if I change:
SUBROUTINE_PATH         = ./:./qtplasmac:../../nc_files/subroutines
to a non existing path:
SUBROUTINE_PATH         = ./:./wqtplasmac:../../nc_files/subroutines
I get this error in terminal:
emc/task/emctask.cc 69: interp_error: File not open
File not open
emc/task/emctaskmain.cc 3070: can't initialize interpreter
plus this error from qtvcp:
  File "/home/phill/git/linuxcnc-dev/lib/python/qtvcp/widgets/system_tool_button.py", line 106, in _set_user_system_text
KeyError: 0
so I don't think it is a qtvcp error, just qtvcp's reaction to not being able to load correctly because of some other pre-existing issue.
