GUI for PlasmaC - QtPlasmac
- phillc54
- Thank you received: 2100
09 Jan 2021 17:47 #194657
by phillc54
Replied by phillc54 on topic GUI for PlasmaC - QtPlasmac
I have no idea, I will try to replicate it. Are you using a package install of LinuxCNC or a run in place install?
- Thank you received: 2181
09 Jan 2021 17:52 #194659
Check to see if the dialog said there was more then one error. keep pressing retry untill you get to the #1 error message.
It might help to pin point the trouble.
Replied by cmorley on topic GUI for PlasmaC - QtPlasmac
but stops with an error sayin QTvcp encountered an error
File "usr/lib/python2.7/dist-packages/qtvcp/widgets/ system_tool_button.py", line 106, in set_user_system_text
self.setText(convert[int(data)])
KeyError: 0
- phillc54
09 Jan 2021 18:26 #194660
by phillc54
I see an issue with the difference in the paths between package and run-in-place which causes a broken link and incomplete file copying when using a package install. I will have to do a bit of work to find a solution...
- robertspark
- Thank you received: 216
09 Jan 2021 19:11 #194662
by robertspark
Replied by robertspark on topic GUI for PlasmaC - QtPlasmac
buildbot package install following live iso install and upgrade
no, just the one error.
- phillc54
09 Jan 2021 19:12 #194663
by phillc54
Yep, that's my bad. I'll let you know when I have a fix...
- snowgoer540
- Thank you received: 907
09 Jan 2021 19:19 - 10 Jan 2021 10:03 #194666
by snowgoer540
Replied by snowgoer540 on topic GUI for PlasmaC - QtPlasmac
EDIT: Moved this error report
here
as there were two separate errors being reported (qtplasmac pathing, and qtvcp widget error) being reported at the same time, muddying the waters.
Last edit: 10 Jan 2021 10:03 by snowgoer540.
- Thank you received: 4155
09 Jan 2021 19:30 #194667
Replied by rodw on topic GUI for PlasmaC - QtPlasmac
Bug is confimed on a compile from source right now on the Plasmac sim
File "/home/plasma2/linuxcnc-dev/bin/qtvcp", line 413, in <module>
APP = QTVCP()
File "/home/plasma2/linuxcnc-dev/bin/qtvcp", line 228, in __init__
window.load_extension(opts.usermod)
File "/home/plasma2/linuxcnc-dev/lib/python/qtvcp/qt_makegui.py", line 246, in load_extension
methods,self.handler_module,self.handler_instance = self._load_handlers([handlerpath], self.halcomp,self)
File "/home/plasma2/linuxcnc-dev/lib/python/qtvcp/qt_makegui.py", line 287, in _load_handlers
objlist = h(halcomp,widgets,self.PATHS) # this sets the handler class signature
File "/home/plasma2/linuxcnc-dev/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 3074, in get_handlers
return [HandlerClass(halcomp, widgets, paths)]
File "/home/plasma2/linuxcnc-dev/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 131, in __init__
self.mode = int(self.iniFile.find('QTPLASMAC', 'MODE')) or 0
TypeError: int() argument must be a string or a number, not 'NoneType'
- phillc54
09 Jan 2021 19:40 #194669
by phillc54
That is a different one, it is because I forgot to rename the [PLASMAC] section of the ini file to [QTPLASMAC]
- phillc54
09 Jan 2021 20:00 #194672
by phillc54
I pushed a fix (I hope
Buildbot will take a while to get to it as it has a couple of builds in queue.
The following user(s) said Thank You: robertspark, snowgoer540
09 Jan 2021 21:28 #194673
Lucky the Aussie day shift is on the ball. Pulled latest master and its working!
Time to create page: 0.366 seconds
