GUI for PlasmaC - QtPlasmac
- Thank you received: 7505
19 Dec 2020 18:16 #192487
Replied by tommylight on topic GUI for PlasmaC - QtPlasmac
Done.set it to :
GUI for PlasmaC - QtPlasmaC
- robertspark
- Thank you received: 216
22 Dec 2020 11:16 #192839
by robertspark
Replied by robertspark on topic GUI for PlasmaC - QtPlasmac
how does one edit the button codes / macros (where are they located)?
- Thank you received: 4155
22 Dec 2020 13:51 #192855
In the ini file. Read the plasmac docs for how to.
Replied by rodw on topic GUI for PlasmaC - QtPlasmac
- snowgoer540
- Thank you received: 907
22 Dec 2020 19:51 - 22 Dec 2020 19:51 #192910
by snowgoer540
Replied by snowgoer540 on topic GUI for PlasmaC - QtPlasmac
I'll just leave these here ...
Last edit: 22 Dec 2020 19:51 by snowgoer540.
The following user(s) said Thank You: cmorley, viesturs.lacis, chimeno, tommylight, rodw, pinder
- robertspark
01 Jan 2021 15:01 #193756
by robertspark
Just a suggestion (I know this is still in development and I know you'll get around to doing it properly with a set of documents for QTPlasmaC), but it may be helpful to use the kindly provided install script before trying to run QTPlasmaC or it will fail on a new clean install of LinuxCNC via live CD with the master branch update
forum.linuxcnc.org/qtvcp/38414-installing-qtvcp#157829
(also means I can find this later when I'm scratching my head trying to get it to work as its a nice clean screenset)
__________________________________________________________
Seperate item.... does no one run a 4th Axis with PlasmaC? (Tube Cutter?)
01 Jan 2021 16:28 #193761
For round tubes just use the X or Y axis as rotary, set the distance for it in ini to the exact circumference of the material you're cutting and that is it. Make a config for each size of tube.
Working on it, but for square tubes.
The following user(s) said Thank You: robertspark
- robertspark
01 Jan 2021 17:24 #193769
by robertspark
I have a rotary plugin for sheetcam and it uses 4 axis for square tube.
This is going to sound a daft question..... but where are the QTPlasmaC screen.ui files saved on install?
(still learning my way around linuxcnc)
Thanks in advance
Thanks in advance
01 Jan 2021 17:30 #193771
Phill, helppppp !
Sheetcam does have 4 axis square tube, but i never used it as it is not included in the free version for Linux.
I have to find a way to pay for it besides cryptocurrencies, and since we got here:
Les, do you accept Bitcoin or Ethereum ?
I was wondering the same thing as the only ui file in the config folder is for the small window with buttons for float/ohmic/etc.This is going to sound a daft question..... but where are the QTPlasmaC screen.ui files saved on install?
Phill, helppppp !
- phillc54
- Thank you received: 2100
01 Jan 2021 17:36 #193774
by phillc54
On a RIP install they are in:
On a package intstall they are in:
Replied by phillc54 on topic GUI for PlasmaC - QtPlasmac
~/linuxcnc-dev/share/qtvcp/screens/qtplasmac (or qtplasmac_4x3 or qtplasmac_9x16)On a package intstall they are in:
/usr/share/qtvcp/screens/qtplasmac (or qtplasmac_4x3 or qtplasmac_9x16)
The following user(s) said Thank You: tommylight, robertspark
- robertspark
09 Jan 2021 17:39 #194656
by robertspark
has something changed in the last couple of days with the 2.9 master?
I ask because when I create a QTPlasmaC instance via the LinuxCNC + select > sample configurations >> QTPlasmaC, and select the "create desktop shortcut"
It doesn't create one,
then when I restart LinucCNC via the configuration selector and select qtplasmac_S_metric it loads
but stops with an error sayin QTvcp encountered an error
File "usr/lib/python2.7/dist-packages/qtvcp/widgets/ system_tool_button.py", line 106, in set_user_system_text
self.setText(convert[int(data)])
KeyError: 0
what have I failed to do in my latest install (I've reinstalled linuxcnc a few times playing around with kernels trying to get an ax200 wifi module running {yes I know the issue with internal wifi.... but it not affecting my latency (yet / I don't think so)
Any guidance as I'm sure its my end would be great, thanks,
KeyError: 0
Time to create page: 0.274 seconds
