File Editor Open Error
- snowgoer540
- Thank you received: 907
13 Feb 2021 10:23 #198689
by snowgoer540
File Editor Open Error was created by snowgoer540
Not sure why, but all of the sudden I get this error when trying to open a file in QtPlasmaC:
Open File Error: Multiple '.' not allowed in Linuxcnc
Unsure if it's a QTVCP thing or a QtPlasmaC thing, I'd assume the first since I think QtPlasmaC is just using the widget.
- Online
- Thank you received: 7504
13 Feb 2021 10:29 #198692
Replied by tommylight on topic File Editor Open Error
Does the config folder name have more than one dot ?
I remember LinuxCNC would not start if there were empty spaces in the config folder name, not sure if that is still the case.
- snowgoer540
13 Feb 2021 11:11 #198695
by snowgoer540
Replied by snowgoer540 on topic File Editor Open Error
No, it's just called qtplasmac-sim.
It worked a day or two ago, so I reckon something in the git pull I did brokeded it
- Thank you received: 2181
13 Feb 2021 12:11 #198698
Replied by cmorley on topic File Editor Open Error
It's a qtvcp thing - a commit was added recently.
I can't get it to fail on my system.
Can you post the actual error?
- snowgoer540
13 Feb 2021 13:20 #198704
by snowgoer540
It just says this:
If there is somewhere else to look, please let me know.
Although, in addition to not being able to open a file, when I click on "USER" I get this error:
File "/home/plasma/linuxcnc-dev/lib/python/qtvcp/widgets/file_manager.py", line 232, in onJumpClicked
self.updateDirectoryView(self._jumpList.get(data))
File "/home/plasma/linuxcnc-dev/lib/python/qtvcp/widgets/file_manager.py", line 194, in updateDirectoryView
if os.path.exists(path):
File "/usr/lib/python2.7/genericpath.py", line 26, in exists
os.stat(path)
TypeError: coercing to Unicode: need string or buffer, NoneType found
os.stat(path)
- snowgoer540
13 Feb 2021 13:23 #198705
by snowgoer540
- snowgoer540
13 Feb 2021 13:33 - 13 Feb 2021 13:35 #198706
by snowgoer540
Ok, I figured out how to replicate it.
My path looks like this /../home/plasma/Downloads/
Clicking .. takes me up a level, but there is no way to delete the /../ in the path.
If I open a new SIM and do a file open, the path is just / and I can navigate to /home/plasma/Downloads. This allows me to open files.
If I click .. too many times to level up, it becomes /../ again, and every path from then forward is /../home/plasma/Downloads, and file open breaks.
Also noteworthy, you can keep clicking .. and get /../../../../../../ There is no way to delete these that I can tell.
Last edit: 13 Feb 2021 13:35 by snowgoer540.
13 Feb 2021 13:42 #198707
are you using python 3?
- snowgoer540
13 Feb 2021 14:23 #198711
by snowgoer540
I don't think so, I think I switched some time back when we thought it might be the reason for another problem.
If you tell me how to check, I'm happy to do so.
It does say "building a Linuxcnc Main Screen with Python 2" if that helps?
13 Feb 2021 14:30 #198714
Ok I pushed a fix for the ../../../ problem which should fix loading.
The jumplist problem is stil amystery.
does the list show User or USER?
can you post your preference file?
Time to create page: 1.336 seconds
