File Editor Open Error
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
13 Feb 2021 14:36 #198716 by snowgoer540
Replied by snowgoer540 on topic File Editor Open Error
Ok I pushed a fix for the ../../../ problem which should fix loading.
thank you!
The jumplist problem is stil amystery.
does the list show User or USER?
can you post your preference file?
I should probably note that I am running it on a VM. I can run down and check on the actual plasma table if necessary.
Prefs attached.
  • snowgoer540
  • Moderator
  • Moderator
13 Feb 2021 14:40 #198717 by snowgoer540
Actually, it's not fixed :(
It's fixed until you double click the file you want to run. Then it adds in all the /../../../../ you did when you were trying to see if it was fixed :laugh:
13 Feb 2021 14:40 #198718 by cmorley
Replied by cmorley on topic File Editor Open Error
Oh I bet Phill overrides the button text and makes it all caps - that will be why if fails.
Ok I'll look into that.
  • snowgoer540
  • Moderator
  • Moderator
13 Feb 2021 14:42 #198719 by snowgoer540
Yea, that's likely. All of the text on QtPlasmaC is capital letters.
Thanks. Only I would do something stupid like click on .. a bunch of times to see if its fixed... but likely someone else will too haha
13 Feb 2021 14:44 #198720 by cmorley
Well don't do that... :)
I was testing in qtdragon (qtplasmca won't run on my system) and it doesn't support double clicking.
I think I know what i missed.
  • snowgoer540
  • Moderator
  • Moderator
13 Feb 2021 14:51 #198721 by snowgoer540
Well, all of the directory clicks are single click. The file name itself requires a double click to actually load.
13 Feb 2021 14:57 #198724 by cmorley
ok try again. both problems should be fixed - fingers crossed.
And QtDragon does support double clicking which I was sure it didn't....
  • snowgoer540
  • Moderator
  • Moderator
13 Feb 2021 14:58 #198726 by snowgoer540
:woohoo:
Both work!
Thanks Chris!
13 Feb 2021 15:00 #198727 by cmorley
Thanks for the initial report and quick fix testing.
  • snowgoer540
  • Moderator
  • Moderator
13 Feb 2021 15:08 #198729 by snowgoer540
Happy to help. Thanks for the quick fixes!
Time to create page: 1.390 seconds
