Change feed override color in QtDragon?
- Thank you received: 2181
04 Mar 2021 15:42 #201055
Sorry developer talk - pushed to the linuxcnc repository.
Then the builbot process will eventually make a new update that you can update to (I assume you used an installed version of linuxcnc)
Replied by cmorley on topic Change feed override color in QtDragon?
When you say code is pushed....... pushed where?
- crowloy
- Thank you received: 19
04 Mar 2021 15:43 - 04 Mar 2021 15:44 #201056
by crowloy
Replied by crowloy on topic Change feed override color in QtDragon?
**removed text**
Last edit: 04 Mar 2021 15:44 by crowloy.
- turbostew
- Thank you received: 8
04 Mar 2021 15:59 #201057
by turbostew
Replied by turbostew on topic Change feed override color in QtDragon?
Thanks,
Have it working!!. I changed mine to be 105% and 95% for over/under. Thanks so much for being so responsive!
04 Mar 2021 16:01 #201058
Great!
Thanks for the interesting ideas
04 Mar 2021 16:03 #201059
here is a reference for other style change ideas:
doc.qt.io/qt-5/stylesheet-examples.html#customizing-qslider
