Touch plate error
- mb_cnc
06 Jun 2021 17:32 #211365
by mb_cnc
Touch plate error was created by mb_cnc
Hello, When running the touch plate routine I'm getting the error message "Parameter file name not found" and the tool table file isn't getting updated with the new length.
SilverDragon
Linuxcnc 2.9 from buildbot.
thanks
SilverDragon
thanks
06 Jun 2021 18:11 #211386
Replied by andypugh on topic Touch plate error
This sounds like a mis-match between your INI file and the files in your config.
Can you paste the _exact_ error message, including which file is not found, and also attach the INI file from your config folder?
- mb_cnc
08 Jun 2021 20:54 #211577
by mb_cnc
Replied by mb_cnc on topic Touch plate error
Andy, thanks for the reply. Here is what I think you were asking for but I'm not sure what file is missing? Or could it be a missing parameter and not a file?
--- Qtvcp Screen Started on: Tue, Jun 08 2021 07:41:17 PM ---
Tue08 19:41 Machine OFF
Tue08 19:41 Hard limits tripped
Tue08 19:41 Tool 0: No Tool
Tue08 19:41 Machine ON
Tue08 19:42 Loaded tool 5
Tue08 19:42 Tool 5: 12D X 12S X 35CL X 75L X 3F X US STRAIGHT
Tue08 19:42 Touchoff to touchplate started
Tue08 19:42 Parameter file name is missing
Tue08 19:43 Saving Status file to status_07:43:36_PM.txt
Tue08 19:43 Saving Status file to status_07:43:37_PM.txt
- Thank you received: 2181
08 Jun 2021 23:53 #211588
Replied by cmorley on topic Touch plate error
I get that message alot when linuxcnc aborts -I haven't trued to track it done yet.
The parameter file name is fine (in my case - in master)
11 Jun 2021 09:21 #211809
Does the linuxcnc.var file exist?
[RS274NGC]
#PARAMETER_FILE = qtdragon.var
PARAMETER_FILE = linuxcnc.varDoes the linuxcnc.var file exist?
- mb_cnc
11 Jun 2021 22:26 #211849
by mb_cnc
Andy, yes the file linuxcnc.var does exist in the machine config folder. I created another machine with pncconf as a test and it is coming up with the same error as well?
- mb_cnc
13 Jun 2021 10:28 #211946
by mb_cnc
The error happens during the running of the touch plate routine. It is after the measurement step and what seems to be a missing formula variable, missing file or a writing error. Not sure? Any help would be appreciated.
thanks
thanks
15 Jun 2021 17:52 #212150
Can you show us the code of the touch plate routine? Is it built-in to Silverdragon?
- mb_cnc
16 Jun 2021 22:00 #212255
by mb_cnc
I searched and It seemed built in so I downloaded the source code to see. Here is what seems to be the code located in qtdragon_handler.py.
def touchoff(self, selector):
if selector == 'touchplate':
z_offset = float(self.w.lineEdit_touch_height.text())
elif selector == 'sensor':
z_offset = float(self.w.lineEdit_sensor_height.text()) - float(self.w.lineEdit_work_height.text())
else:
self.add_status("Unknown touchoff routine specified")
return
self.add_status("Touchoff to {} started".format(selector))
max_probe = self.w.lineEdit_max_probe.text()
search_vel = self.w.lineEdit_search_vel.text()
probe_vel = self.w.lineEdit_probe_vel.text()
ACTION.CALL_MDI("G21 G49")
ACTION.CALL_MDI("G10 L20 P0 Z0")
ACTION.CALL_MDI("G91")
command = "G38.2 Z-{} F{}".format(max_probe, search_vel)
if ACTION.CALL_MDI_WAIT(command, 10) == -1:
ACTION.CALL_MDI("G90")
return
if ACTION.CALL_MDI_WAIT("G1 Z4.0"):
return
ACTION.CALL_MDI("G4 P0.5")
command = "G38.2 Z-4.4 F{}".format(probe_vel)
return
command = "G10 L20 P0 Z{}".format(z_offset)
ACTION.CALL_MDI_WAIT(command)
command = "G1 Z10 F{}".format(search_vel)
else:
return
return
return
return
17 Jun 2021 23:28 #212308
I can get this error message by aborting running code.
but not in all qt screens.
with print statements I can see the cc code is getting the right ini/param file.
This is a mystery.
This is a mystery.
Time to create page: 1.706 seconds
