Can't run first job with qtdragon_hd
4 years 10 months ago #229756 by ucancallmebob89
Replied by ucancallmebob89 on topic Can't run first job with qtdragon_hd
That was super helpful, thank you! I didn't realize qtdragon_hd.ui had the color and off-color both defined as green by default. That really should be changed to avoid this confusion.
4 years 10 months ago #229758 by ucancallmebob89
Ok so after cleaning up my .hal files this is what I have right now in my PrintNC config folder. I'm still seeing the behavior where the job hangs at line 16.
I did a HAL show on several relevant pins.
In my custom_postgui.hal I have these spindle settings:
And in vfd.hal I have these spindle settings:
Do I need a line that does "setp spindle-at-speed true"? Because I thought the point of having the serial connection to the VFD is that it can tell me when it is at speed instead of manually setting it.
4 years 10 months ago #229788 by ucancallmebob89
So I'm thinking now that this is not a spindle-at-speed problem. I just did hal show on a bunch of spindle and vfd related pins while running the spindle manually and then while attempting to run my gcode file.
Manually turning spindle on:
Running my gcode file:
Everything seems to be working fine when I turn on the spindle in manual mode. Is there something weird going on in my gcode file?
4 years 10 months ago #229794 by cmorley
Replied by cmorley on topic Can't run first job with qtdragon_hd
your program runs fine on a sim config.
4 years 10 months ago - 4 years 10 months ago #229814 by ucancallmebob89
Progress! It has to do with my toolchange operation. I started commenting out one line at a time in my gcode file and it was able to run after I commented out "T3 M6".
Now I just have to figure out why that's causing a problem.
Here are my toolchange related config settings. I'm using a manual toolchange operation. I want the machine to go to G53 X100 Y100 Z0. I have TOOL_CHANGE_QUILL_UP = 1 because I want it to raise Z all the way up before moving to the toolchange position.
In my INI, here's my EMCIO section:
[EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl TOOL_CHANGE_WITH_SPINDLE_ON = 0 TOOL_CHANGE_QUILL_UP = 1 TOOL_CHANGE_POSITION = 200 100 0
In my postgui file, here's my tool change info. I've tried it with the unlinkp lines commented and uncommented, and it hasn't changed the behavior.
# the unlink pin commands are only used, because they are connected # in core_sim.hal and we use this file to simulate # unlinkp iocontrol.0.tool-change # unlinkp iocontrol.0.tool-changed # unlinkp iocontrol.0.tool-prep-number     net tool-change         hal_manualtoolchange.change   <=  iocontrol.0.tool-change net tool-changed        hal_manualtoolchange.changed  <=  iocontrol.0.tool-changed net tool-prep-number    hal_manualtoolchange.number   <=  iocontrol.0.tool-prep-number
According to this , I expected a little message box to appear showing to facilitate the manual toolchange, but that never happened.
Last edit: 4 years 10 months ago by ucancallmebob89.
4 years 10 months ago #229820 by hottabich
Replied by hottabich on topic Can't run first job with qtdragon_hd
Try replacing the Tool.tbl file to the attached and everything will work.
Time to create page: 1.604 seconds
