Display message in dialog box on gpio
  • ikkuh
  • ikkuh's Avatar Topic Author
  • Elite Member
  • Elite Member
20 Jan 2022 08:37 #232526 by ikkuh
I would like to display a message when the sensor on my water cooling pump is not working.
The sensor functions and is tied to a io pin, that part already works and makes it impossible to put the machine in an 'on' state when the pump is malfunctioning. And if the pin goes low when the machine state is on then the machine state is switched to 'off'.
What I would like is a message popping up when the waterpump is stopped and the operator tries to switch the machine to an 'on' state.
How do I do that?
  • Moderator
  • Moderator
20 Jan 2022 08:43 #232528 by tommylight
The following user(s) said Thank You: ikkuh
  • ikkuh
  • Elite Member
  • Elite Member
20 Jan 2022 08:45 #232530 by ikkuh
Replied by ikkuh on topic Display message in dialog box on gpio
This should do:
linuxcnc.org/docs/2.8/html/man/man9/message.9.html
oops my fault, should have searched better.
Thanks!
20 Jan 2022 15:48 #232555 by cmorley
Replied by cmorley on topic Display message in dialog box on gpio
Qtvcp version:
linuxcnc.org/docs/devel/html/gui/qtvcp_libraries.html#_messages
If you need a version that can't be cleared by the user - we could add that.
  • ikkuh
  • Elite Member
  • Elite Member
21 Jan 2022 02:35 #232607 by ikkuh
Wow, that would be great. A blocking dialog box so that the operator is forced to take action, would love to have that in qtDragon!
Great idea.
22 Jan 2022 18:32 #232846 by cmorley
ok pushed work for this to master.
This will produce a button-less dialog then appears and disappears by a HAL bit pin.
MESSAGE_BOLDTEXT = Critical and Persistent
MESSAGE_TEXT = This is a persistent dialog test
MESSAGE_DETAILS = There seems to be something wrong You must fix it to clear message
MESSAGE_TYPE = nonedialog
MESSAGE_PINNAME = nonedialogtest
MESSAGE_ICON = CRITICAL
and qt styles work on them.
It was a very large change so hopefully didn't break anything.
I haven't updated the docs yet
  • ikkuh
  • Elite Member
  • Elite Member
23 Jan 2022 05:30 #232871 by ikkuh
Wow, thank you! Will try this this afternoon. Will  let you know my experiences.
Thanks!
  • ikkuh
  • Elite Member
  • Elite Member
23 Jan 2022 10:15 #232887 by ikkuh
Sorry, can not get it to work. The regular message system does work.
Please supply an example how you tested the new functionality, I probably made a silly mistake.
cnc@cncmachine:~/linuxcnc/configs/qt$ linuxcnc qt.ini
LINUXCNC - 2.9.0-pre0-5607-gfc9ea3e5c
Machine configuration directory is '/home/cnc/linuxcnc/configs/qt'
Machine configuration file is 'qt.ini'
Starting LinuxCNC...
Found file(REL): ./qt.hal
Note: Using POSIX realtime
identityKinematicsSetup: coordinates:XYYZ
23 Jan 2022 10:37 #232889 by cmorley
Under the heading {DISPLAY} add:
run the config and a HAL pin qtdragon.nonedialogtest will be available.
set that pin true to show, false to hide.
The sim 'qtdragon.ini' (only that one) has three dialogs included - that's how I tested.
Chris
  • ikkuh
  • Elite Member
  • Elite Member
23 Jan 2022 12:09 #232897 by ikkuh
As I expected I made a silly mistake.
Works now! Thank you very much.
Will post relevant code soon here.
Time to create page: 0.098 seconds
