Display message in dialog box on gpio
- ikkuh
- Thank you received: 48
24 Jan 2022 06:17 - 25 Jan 2022 00:54 #232952
by ikkuh
Replied by ikkuh on topic Display message in dialog box on gpio
Great to have this working now. When there is no pressure from the spindle water cooling pump the machine will turn off when it was on, then a blocking dialog box will show on the screen. Nothing works until the error is fixed.
By turning the machine off the spindle will stop too.
(did I ever mention the editor of the forum software totally sucks?)
imgur.com/I3sGcmR
qt.ini
[DISPLAY]
MESSAGE_BOLDTEXT = Water pomp staat uit
MESSAGE_TEXT = De waterkoeling pomp van de spindle staat uit of werkt niet meer.
MESSAGE_DETAILS = Na oplossen van de fout verdwijnt deze boodschap vanzelf
MESSAGE_TYPE = nonedialog
MESSAGE_PINNAME = no-coolant
MESSAGE_ICON = CRITICAL
imgur.com/I3sGcmR
qt.ini
[DISPLAY]
loadrt or2 names=tool_probe,vacuumOr2,machineOnOr2
addf tool_probe servo-thread
addf vacuumOr2 servo-thread
addf machineOnOr2 servo-thread
net btn-pwr <= input.0.btn-top2 => machineOnOr2.in0
net coolant-pump <= [HMOT](CARD0).7i84.0.0.input-00 => machineOnOr2.in1
net pwr-btn toggle2Power.in machineOnOr2.out qtdragon.no-coolant
net tog-on toggle2Power.is-on <= halui.machine.is-on => [HMOT](CARD0).gpio.037.out
net pwr-on halui.machine.on <= toggle2Power.on
net pwr-off halui.machine.off <= toggle2Power.off
Last edit: 25 Jan 2022 00:54 by cmorley. Reason: reason is that this editor totaLYU BLOWS!!!!!!!!!!!!!!!!!
- APDent
04 Sep 2024 05:31 #309345
by APDent
Replied by APDent on topic Display message in dialog box on gpio
Hi Chris
How can I use your MESSAGE_TYPE = nonedialog in Gmoccapy 3.4.6? (LCNC 2.9.2, Debian 12)
Cheers
Wayne
Cheers
Wayne
- Thank you received: 2181
07 Sep 2024 10:20 #309581
Replied by cmorley on topic Display message in dialog box on gpio
At the moment I think you would need to make a VCP panel using qtvcp and embed it into gmoccapy. That would give you access to Qtvcp's messaging functions.
It could probably be done using gmoccapy's USER_COMMAND_FILE options but I have never trued that.
16 Sep 2024 23:41 #310290
I pushed some work to master to make this easier.
There is a sim demo: gmoccapy_qt_messages
The dialog HAL pins are:
ini_dialogs.VFD
ini_dialogs.VFD-waiting
ini_dialogs.bothtest
ini_dialogs.bothtest-waiting
ini_dialogs.VFD is a S32 and can be set to 0,1,2,3 for three different messages (0 to hide)
ini_dialogs.bothtest is a bit which will show the one dialog message.
Chris
ini_dialogs.VFD
Chris
Time to create page: 0.081 seconds
