[QtDragon] Simple vismach window
- Abdulkareem
28 Feb 2024 03:55 #294681
by Abdulkareem
Replied by Abdulkareem on topic [QtDragon] Simple vismach window
hello, could you please tell me where to write this script
- Thank you received: 2177
28 Feb 2024 06:52 #294693
Replied by Aciera on topic [QtDragon] Simple vismach window
The vismach model is a python file that creates it's own hal pins and is loaded as a user component from hal.
For Qtvismach it is a bit more complicated than for a regular configuration.
You will need to place your actual vismach file in this folder:
<your_path_here>/lib/python/qtvcp/lib/qt_vismach
Then you also need a folder with a .ui and handle.py file for your vismach simulation here:
<your_path_here>/share/qtvcp/panels
Take a look at one of the preinstalled qtvismach simulations (eg millturn) as a reference.
The following user(s) said Thank You: Abdulkareem
- Thank you received: 2181
01 Mar 2024 22:52 #294883
Replied by cmorley on topic [QtDragon] Simple vismach window
You shouldn't need to put the vismach file in <your_path_here>/lib/python/qtvcp/lib/qt_vismach.
I've tested a compiled version to confirm but not an installed version.
Also (to be complete) you only need to use an ui/handler file if you want to embed the window or want to add other widgets.
You can load the vismach file directly with python3 - good for testing vismach changes.
Time to create page: 0.482 seconds
