missing lib/python/qtvcp/designer
  • LearningLinuxCNC
  • LearningLinuxCNC's Avatar Topic Author
  • Elite Member
  • Elite Member
05 Apr 2022 16:19 #239356 by LearningLinuxCNC
missing lib/python/qtvcp/designer was created by LearningLinuxCNC
I am trying to get started on editing QtDragon for a custom application. This is my first Qtvcp project. So I am trying to get it set up. I installed QtDesigner that looks to be working. However when I get to the python-module loading library I am running into an issue. I am missing the directory on the machine lib/python/qtvcp/designer in fact I don't have lib/python directory. I have lib/pyshared, lib/python2.6, lib/python2.7, lib/python3 and lib/python3.7 none of which have the /qtvcp/designer subfolders.
How do I go about getting the precompiled python-module loading library?
Thanks,
Jim
  • LearningLinuxCNC
  • Elite Member
  • Elite Member
05 Apr 2022 18:45 #239368 by LearningLinuxCNC
Replied by LearningLinuxCNC on topic missing lib/python/qtvcp/designer
I have found the files that I could not locate. They are located at the following location
/usr/lib/python2.7/dist-packages/qtvcp/designer/
there are options for 5.5 5.7 and 5.9 per the instructions.
It does not appear that I have any of those three installed on this machine. This machine is configured from the 2.8.0 iso.
After installing designer per the qtvcp instructions
[i]sudo apt-get install qttools5-dev-tools[/i]
[i]sudo apt-get install qttools5.dev[/i]
in designer and in synaptic package manager it appears the version of qt5 installed is 5.11.3
What is the appropriate version to install on debian buster?
06 Apr 2022 03:05 #239413 by cmorley
Replied by cmorley on topic missing lib/python/qtvcp/designer
is there a file named install script in the qtvcp/designer folder?
There is a 5.11 library available but not released yet.
  • LearningLinuxCNC
  • Elite Member
  • Elite Member
06 Apr 2022 13:01 #239440 by LearningLinuxCNC
Chris,
There is no file named script in the qtvcp/designer folder.
I downloaded your tar.gz file placed it in a folder called:
/usr/lib/python2.7/dist-packages/qtvcp/designer/x86_64/qt5.11
extracted it and copied it to:
/usr/lib/x86_64-linux-gnu/qt5/plugins/designer/libpyqt5_py2.so
opened designer and the widgets still don't appear.
  • LearningLinuxCNC
  • Elite Member
  • Elite Member
06 Apr 2022 20:51 #239474 by LearningLinuxCNC
I installed all of the dependencies for building linuxcnc.
Now when I try to launch designer I get the following.
:~$ designer -qt=5
  File "/home/sboperator/.designer/plugins/python/qtvcp_plugin.py", line 22, in <module>
    from qtvcp.plugins.simplewidgets_plugin import *
ModuleNotFoundError: No module named 'qtvcp'
Segmentation fault
07 Apr 2022 00:48 #239489 by cmorley
If you are running a compiled RIP version of linuxcnc you need to run:
. scripts/rip-environment
before running designer.
I thought you were using an installed version of linuxcnc in which you don't need to do that.
The error message seems to indicate it doesn't find qtvcp.
In a terminal can you run the command 'qtvcp' and see what it says?
  • LearningLinuxCNC
  • Elite Member
  • Elite Member
07 Apr 2022 01:35 #239494 by LearningLinuxCNC
This is an installed version from 2.8.0 iso.
I downloaded all build dependencies today so I could build a kinematics module. I had issue with that also. It is in another post.
When I run qtvcp i get the following
:~$ qtvcp
[QtDesigner][INFO] Logging to "/home/sboperator/qtdesigner.log" (logger.py:88)
[QTvcp][INFO] Logging to "/home/sboperator/qtvcp.log" (logger.py:88)
[QTvcp][INFO] Base log level set to 20 (logger.py:52)
[QtDesigner.QTVCP.QT_PSTAT][DEBUG] BASENAME dummy (qt_pstat.py:58)
[QtDesigner.QTVCP.QT_PSTAT][DEBUG] Checking for handler file in: /home/sboperator/dummy_handler.py (qt_pstat.py:78)
[QtDesigner.QTVCP.QT_PSTAT][DEBUG] Checking for default handler file in: /usr/share/qtvcp/panels/dummy/dummy_handler.py (qt_pstat.py:84)
  • LearningLinuxCNC
  • Elite Member
  • Elite Member
07 Apr 2022 01:36 #239495 by LearningLinuxCNC
And the rest because the forum would not let me put this all in one post. . .
[code][QtDesigner.QTVCP.QT_PSTAT][INFO] No handler file found (qt_pstat.py:90)
[QtDesigner.QTVCP.QT_PSTAT][DEBUG] Checking for .ui in: /home/sboperator/dummy.ui (qt_pstat.py:104)
[QtDesigner.QTVCP.QT_PSTAT][DEBUG] Checking for .ui in: /usr/share/qtvcp/panels/dummy/dummy.ui (qt_pstat.py:109)
[QtDesigner.QTVCP.QT_PSTAT][CRITICAL] No UI file found - Did you add the .ui name/path? (qt_pstat.py:116)
[QtDesigner.QTVCP.QT_PSTAT][ERROR] Available built-in VCP Panels: (qt_pstat.py:125)
cam_align
sim_panel
[/code]
  • LearningLinuxCNC
  • Elite Member
  • Elite Member
07 Apr 2022 01:38 #239496 by LearningLinuxCNC
Designer was opening earlier before downloading the build dependencies. Now it will not open.
07 Apr 2022 05:34 #239502 by cmorley
Did you copy this file to here or use a system link (should be a system link)?
Here is the install script (unzip it) maybe that will be easier.
Chris
The following user(s) said Thank You: LearningLinuxCNC
Time to create page: 0.264 seconds
