- Thank you received: 39
missing lib/python/qtvcp/designer
- LearningLinuxCNC
- Topic Author
4 years 6 months ago #239494
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic missing lib/python/qtvcp/designer
This is an installed version from 2.8.0 iso.
I downloaded all build dependencies today so I could build a kinematics module. I had issue with that also. It is in another post.
When I run qtvcp i get the following
:~$ qtvcp
[QtDesigner][INFO] Logging to "/home/sboperator/qtdesigner.log" (logger.py:88)
[QTvcp][INFO] Logging to "/home/sboperator/qtvcp.log" (logger.py:88)
[QTvcp][INFO] Base log level set to 20 (logger.py:52)
[QtDesigner.QTVCP.QT_PSTAT][DEBUG] BASENAME dummy (qt_pstat.py:58)
[QtDesigner.QTVCP.QT_PSTAT][DEBUG] Checking for handler file in: /home/sboperator/dummy_handler.py (qt_pstat.py:78)
[QtDesigner.QTVCP.QT_PSTAT][DEBUG] Checking for default handler file in: /usr/share/qtvcp/panels/dummy/dummy_handler.py (qt_pstat.py:84)
- LearningLinuxCNC
- Topic Author
4 years 6 months ago #239495
by LearningLinuxCNC
And the rest because the forum would not let me put this all in one post. . .
[/code]
[code][QtDesigner.QTVCP.QT_PSTAT][INFO] No handler file found (qt_pstat.py:90)
[QtDesigner.QTVCP.QT_PSTAT][DEBUG] Checking for .ui in: /home/sboperator/dummy.ui (qt_pstat.py:104)
[QtDesigner.QTVCP.QT_PSTAT][DEBUG] Checking for .ui in: /usr/share/qtvcp/panels/dummy/dummy.ui (qt_pstat.py:109)
[QtDesigner.QTVCP.QT_PSTAT][CRITICAL] No UI file found - Did you add the .ui name/path? (qt_pstat.py:116)
[QtDesigner.QTVCP.QT_PSTAT][ERROR] Available built-in VCP Panels: (qt_pstat.py:125)
cam_align
sim_panel
[/code]
- LearningLinuxCNC
- Topic Author
4 years 6 months ago #239496
by LearningLinuxCNC
Designer was opening earlier before downloading the build dependencies. Now it will not open.
4 years 6 months ago #239502
Replied by cmorley on topic missing lib/python/qtvcp/designer
Did you copy this file to here or use a system link (should be a system link)?
/home/sboperator/.designer/plugins/python/qtvcp_plugin.py
Here is the install script (unzip it) maybe that will be easier.
Chris
Chris
The following user(s) said Thank You: LearningLinuxCNC
- LearningLinuxCNC
- Topic Author
4 years 6 months ago #239530
by LearningLinuxCNC
Chris,
I did create a symlink to the file qtvcp_plugin.py. and placed it in the specified directory.
However, after running the script all is well. Thank you for your support on this.
If you have a chance could you take a look at the issue I am having compiling a kinematics module.
forum.linuxcnc.org/10-advanced-configura...compiling-kinematics
Time to create page: 0.257 seconds
