Need help connecting vfdmod and Qtdragon_HD
- dashy81
- Thank you received: 3
10 Dec 2022 22:45 #259150
by dashy81
Replied by dashy81 on topic Need help connecting vfdmod and Qtdragon_HD
Thanks...I think you are looking at old files... pls look at the link I provided. containing zipped files. https:/easyupload.io/u91hoz
- dashy81
10 Dec 2022 22:47 #259151
by dashy81
Thnakyou Rob But as Andy mentioned later guess thats not needed, But I'll still give it a try.
- Thank you received: 7478
10 Dec 2022 22:55 #259154
Replied by tommylight on topic Need help connecting vfdmod and Qtdragon_HD
Pleas upload the files here on this forum, not on third party sites.
Thank you.
Thank you.
- dashy81
10 Dec 2022 23:00 #259156
by dashy81
Thanks Andy.... I've a working AXIS configuration with vfdmod. It works as it is without any issues(github.com/xsnoopy/LinuxCNC-Yalang-yl620...s485-Modbus---VFDmod). I tried comparing it to my qtdragon_hd config but due to lack of expertise on lcnc could not compare them as files are not same. This one which is mentioned at the very first post of this thread.... Before moving to qtdragon_hd I've used it and found it to be working fine.
So I'll check same signal there and update. Also I'll post the working AXIS configuration files, for experts to compare as both are on same yl620a and on same machine. One working other not.
- Thank you received: 2181
10 Dec 2022 23:04 #259157
Replied by cmorley on topic Need help connecting vfdmod and Qtdragon_HD
Thanks for the zipped files. I now see that all the right files are loaded.
I believe your vfd communication is not working properly.
I see in your HAL pile you are using the VFD to send speed feedback to linuxcnc and qtdragon is not seeing it either.
again start qtdragon open halmeter and look at pin vfdmod.spindle.rpm-out.
It should show RPM when you start the spindle - even manually.
In fact I would look at all the vfdmod pins with halmeter to see if their state/change of state is making sense.
Chris
Chris
10 Dec 2022 23:42 #259161
I see axis uses spindle.0.speed-out-abs, qtdragon doesn't.
Also in axis, vfdmod.spindle.rpm-out goes directly to spindle.0.speed-in,
which is actually probably not right - spindle.0.speed-in is expected to be RPS not RPM.
In qtdragon I believe it's scaled right but named badly (scale_to_rpm)
#AXIS
net spindle-forward vfdmod.control.run-forward spindle.0.forward
net spindle-reverse vfdmod.control.run-reverse spindle.0.reverse
net spindle-speed-in vfdmod.spindle.rpm-in spindle.0.speed-out-abs
net spindle-speed-out vfdmod.spindle.rpm-out spindle.0.speed-in pyvcp.rpm-out#QTDragon
net spindle-cw spindle.0.forward => vfdmod.control.run-forward
net spindle-ccw spindle.0.reverse => vfdmod.control.run-reverse
net spindle-speed spindle.0.speed-out => vfdmod.spindle.rpm-in
net spindle-speed-fb <= vfdmod.spindle.rpm-outI see axis uses spindle.0.speed-out-abs, qtdragon doesn't.
- looping
- Thank you received: 10
01 Sep 2023 10:41 - 01 Sep 2023 15:15 #279561
by looping
Replied by looping on topic Need help connecting vfdmod and Qtdragon_HD
Hello
I followed this thread to connect my huanyang 2.2kw using hy_vfd.
But error-count and .retval for error management are parameters, not pins.
Is there a way to connect then to Qtdragon_hd display ?
Last edit: 01 Sep 2023 15:15 by looping.
01 Sep 2023 20:08 #279607
Do I understand right - the VFD driver has output parameter pins?
You could change to pins in the VFD driver (and recompile)
you could modify qtdragon to read the parameter pins programmatically rather then connect with pins (means modifying qtdragon a bit)
- looping
02 Sep 2023 09:43 - 02 Sep 2023 10:23 #279653
by looping
Last edit: 02 Sep 2023 10:23 by looping.
- looping
03 Sep 2023 14:17 #279719
by looping
To be able to link hy_vfd directly to QtdragonHD
Also added spindle_speed_fb_rps to get ride of : "loadrt scale names=scale_to_rpm"
Time to create page: 0.143 seconds
