Need help connecting vfdmod and Qtdragon_HD
3 years 2 months ago - 3 years 2 months ago #279561 by looping
Hello
I followed this thread to connect my huanyang 2.2kw using hy_vfd.
But error-count and .retval for error management are parameters, not pins.
Is there a way to connect then to Qtdragon_hd display ?
Last edit: 3 years 2 months ago by looping.
3 years 2 months ago #279607 by cmorley
Do I understand right - the VFD driver has output parameter pins?
You could change to pins in the VFD driver (and recompile)
you could modify qtdragon to read the parameter pins programmatically rather then connect with pins (means modifying qtdragon a bit)
3 years 1 month ago - 3 years 1 month ago #279653 by looping
... Installing dev toolsimage missing /media/kunena/emoticons/tongue.png
Modifying hy_vfd
Last edit: 3 years 1 month ago by looping.
3 years 1 month ago #279719 by looping
To be able to link hy_vfd directly to QtdragonHD
Also added spindle_speed_fb_rps to get ride of : "loadrt scale names=scale_to_rpm"
3 years 1 month ago #279760 by cmorley
We should add this to out sources. thanks.
3 years 1 month ago #279761 by looping
I can make a PR if you want
Time to create page: 0.389 seconds
