How to enable wait for spindle-at-speed in QTDragon
- kas1kas
18 Sep 2022 08:44 #252247
by kas1kas
Replied by kas1kas on topic How to enable wait for spindle-at-speed in QTDragon
lsb_release -sa: Debian Debian GNU/Linux 10 (buster) 10 buster
LINUXCNC - 2.9.0-pre0-7591-ga7fc80b3a
- Thank you received: 2175
18 Sep 2022 12:54 #252258
Replied by cmorley on topic How to enable wait for spindle-at-speed in QTDragon
I'll tell you here. I'm just very busy at work right now so have limited time.
- kas1kas
18 Sep 2022 18:56 #252284
by kas1kas
No problem! Something for another day. Thanks for the support.
20 Sep 2022 03:42 #252374
ok on your next update, there should be an output HAL pin called 'qtdragon.spindle-is-at-speed'
It uses qtvcp's internal calculation for at-speed. +- 10% by default
Chris
Chris
The following user(s) said Thank You: OGMaker
- kas1kas
20 Sep 2022 08:33 #252385
by kas1kas
Thanks already Chris.
That makes it so much easier for new installs!
regards, Kas
regards, Kas
Time to create page: 0.156 seconds
