A few issues with the qtdragon (Linuxcnc 2.9)
- Thank you received: 2175
30 Oct 2022 23:09 #255510
Replied by cmorley on topic A few issues with the qtdragon (Linuxcnc 2.9)
Probe Basic the GUI, (I agree - bad name) is not in the linuxcnc project - It's a separate project all together.
Probe basic the widget, is included in linuxcnc and is probably a knockoff of the above's probe screen.
- Thank you received: 7466
30 Oct 2022 23:52 #255519
Replied by tommylight on topic A few issues with the qtdragon (Linuxcnc 2.9)
I would argue the probe basic widget was here before probe basic GUI.
Probe basic GUI started it's life after the "brendaEM" "incident", while i recall the widget being here before that in conjunction with "verseBY" or something similar.
Then again, i might be wrong....
31 Oct 2022 06:38 - 31 Oct 2022 06:39 #255546
Not sure what you mean by 'here'? Here as on the forum?
The probe basic GUI came first but as I said, is a separate project from linuxcnc.
This was after Kurt decided to start his own project rather then work on qtvcp.
Then basic probe (just the probe part) was 'ported' to linuxcnc's qtvcp project.
There is also a similar situation with versa probe.
Being linux based, there is always multiple direction to take, with often confusing names
Last edit: 31 Oct 2022 06:39 by cmorley.
31 Oct 2022 06:44 - 31 Oct 2022 06:45 #255547
I'll have to test it specifically to be sure, but I do believe it is functional.
I did see a place for improvement in the future. When testing the round boss probing, I noticed that
the back off (step off) setting is not taken into account when probing the opposite side.
I had set the back off very large .5 inch and then it would not move to the other side quite enough.
When I have more time I will test more and add to the docs.
This looks great! I thought Max Z distance was not implemented though, did that change?\
Last edit: 31 Oct 2022 06:45 by cmorley.
- itsme
31 Oct 2022 09:07 #255554
by itsme
What was the brendaEM incident you are referring to?
Replied by itsme on topic A few issues with the qtdragon (Linuxcnc 2.9)
For the newbies:I would argue the probe basic widget was here before probe basic GUI.
31 Oct 2022 12:25 #255563
The following user(s) said Thank You: itsme
Time to create page: 0.143 seconds
