QtDragon_HD Preview window
13 Jan 2023 14:25 #261798 by Zavrl
QtDragon_HD Preview window was created by Zavrl
Hello,
I have two questions regarding the completed toolpath review window.
1.
I noticed that in the review window, after a certain number of G-code steps, the realized toolpaths start to be deleted.
This is quite annoying when I'm doing V-carve where there is no set tool sequence and then it's never visible where the tool has been.
In the instructions, I can't find a description of where and how to set it to work but not delete the path.
What and where I have to change this option?
2.
The GUI allows you to resume work from a specific line of G-code. This is a well. If the electronics report an error during operation, the execution of the program is interrupted and the overview window for the G-code is placed at the beginning.
Is it possible somewhere to see the information on which G-code line the error was? It is not on the STATUS screen, not even in the LOG file.
Is it possible to supplement the overview window with the functionality that the Axis GUI has, to click with the mouse on the drawn G-code position and in the G-code overview the cursor is placed on the drawn G-code line.
13 Jan 2023 19:51 #261823 by cmorley
Replied by cmorley on topic QtDragon_HD Preview window
1) This was noticed by someone else and I thought it got fixed - I'll have to look for the details.
How old/current is your version of linuxcnc and how did you get it (debian repo,buildbor,compiled)?
2) I'll look into that - if it's a gcode error, does the error message not report the line?
3)in the setting tab 'inhibit mouse selection' controls this. If your program is large, it really slows down the rotation etc of the graphics.
13 Jan 2023 20:02 #261825 by cmorley
Is your 1) problem similar to this:
forum.linuxcnc.org/qtvcp/41566-seems-lik...highlighting?start=0
Are you using 2.9?
  • scotth
  • Elite Member
  • Elite Member
14 Jan 2023 00:31 #261841 by scotth
Replied by scotth on topic QtDragon_HD Preview window
I see it in AXIS 2.9.0~pre0+git20221105.ffb6bda926 also.
14 Jan 2023 00:50 #261843 by cmorley
Do you have the ability to try master branch?
  • scotth
  • Elite Member
  • Elite Member
14 Jan 2023 01:00 #261844 by scotth
I should clone my hard drive first. I am testing several things now.
Testing Release Linux Mint 21.1 Vera 64-bit with Kernel Linux 6.1.0-rt5-linuxcnc-rt x86_64.
This might not be your best test bed now.
14 Jan 2023 01:25 #261845 by cmorley
Are you compiling from source? its a one line change to try
  • scotth
  • Elite Member
  • Elite Member
14 Jan 2023 03:29 #261858 by scotth
No deb only.
14 Jan 2023 03:45 #261863 by cmorley
Ok. Could you post a ngc file that shows the problem?
keeping in mind this is a public forum if that is important to you.
  • scotth
  • Elite Member
  • Elite Member
14 Jan 2023 05:19 - 14 Jan 2023 05:21 #261891 by scotth
It was a test file for G93 problems. The tools and tool changes are removed.
QTDragon fails in sim with my config now.
XYZB config
Last edit: 14 Jan 2023 05:21 by scotth.
Time to create page: 0.209 seconds
