Modifing QTVCP xml for Qtdragon_hd?
- akg1904
- Thank you received: 4
21 Jan 2023 05:49 #262553
by akg1904
Modifing QTVCP xml for Qtdragon_hd? was created by akg1904
I am trying to modify QtDragon_hd xml files for my custom requirement.
But the xml file in qtvcp does not support "multi-label","legends","bar","button" etc.
Is there any other way to have this "multi-label","legends","bar","button" etc. working in Qtvcp xml files.
or is there any alternative of this?
We can check different xml files of other ini files(such as switchkins etc.) to find the uses of above syntax.
Regards
Abhishek
Regards
Abhishek
- Thank you received: 2170
21 Jan 2023 08:58 #262565
Replied by cmorley on topic Modifing QTVCP xml for Qtdragon_hd?
Please explain where you found : "multi-label","legends","bar","button"
Is this from pyvcp?
Is this from pyvcp?
- akg1904
21 Jan 2023 11:22 #262568
by akg1904
Replied by akg1904 on topic Modifing QTVCP xml for Qtdragon_hd?
Yes it is from pyvcp.
21 Jan 2023 22:12 #262614
There is no equivalent to multi label in qtvcp (you could build it yours self though)
You could use a general_hal_input to connect to a QProgess bar for a bar
Not sure what legends are.
and a HAL pushbtton works like a button in pyvcp.
You can't use your old XML files if that is what you are hoping.
I could add some of these in the future.
The following user(s) said Thank You: akg1904
22 Jan 2023 06:54 #262632
In 2.9 I have modified hal_label to support multi labels.
Unfortunately no docs yet
- akg1904
23 Jan 2023 04:35 #262707
by akg1904
Thank you for your prompt reply..
Can you please guide me how I can build multi-label and other syntax in QTVCP.
There are few suggestion I feel can be made in QTVCP...
1. Qprogress bar only moves in one direction, we cannot represent both positive and negative progress in single Qprogress bar.
2. It can be made compitable with previous XML syntax(if possible).
Regards
Abhishek
Regards
Abhishek
23 Jan 2023 05:37 #262718
Use designer to add a HAL_Label
Go to the properties tab look for HAL_Label
check the property 'use_multi_label'
set the textTemplate property to %s
double click the property multi_label_list
edit/add the labels in the dialog.
You can use rich text in the textTemplate or in the label list
Ie using as the textTemplate:
<html><head/><body><p><span style=" font-weight:600;">%s</span></p></body></html>
Will make all the labels bold.
Yes I'm considering the best way to create a bar widget.
Chris
Chris
- akg1904
25 Jan 2023 11:08 #262871
by akg1904
Hi Chris,
How can I use "Hal_label" in qtdragon as in QTdesigner I was not able to find Hal_label and more so I was not able to convert Qlabel into Hal_label.
AbhishekÂ
AbhishekÂ
25 Jan 2023 13:57 #262884
Are any oh linuxcnc's widgets available in designer?
- akg1904
27 Jan 2023 04:55 #262979
by akg1904
Hi Chris,
It(general_hal_input,general_hal_output,hal_label) does shows in lib/python/qtvcp/widgets, but it doesn't shows itself in qtdesigner.
