NCGGUI and QtDragon
3 years 8 months ago #264329 by Roguish
NCGGUI and QtDragon was created by Roguish
Well, the docs say one can add ncggui routines to tabs in QtDragon.
I've been through the docs over and over, but just don't get it.
Could someone come up with a simple step by step instruction?   with lots of pictures.....
Sure would be handy.
thanks.
3 years 8 months ago #264335 by cmorley
Replied by cmorley on topic NCGGUI and QtDragon
Some docs just pushed - will take a bit before they are available.
The following user(s) said Thank You: Roguish
3 years 8 months ago #264340 by persei8
Replied by persei8 on topic NCGGUI and QtDragon
To add a new subroutine to ngcgui, do the following:
- press New Tab
- if it has a preamble file, press Select Preamble
- press Select Subfile
- if it has a postamble, press Select Post
- then Create Feature
- then Finalize Gcode
If the SEND checkbox is checked, the created program will be loaded into LinuxCNC. If the SAVE checkbox is checked, the program will be saved to a file.
NGCGUI programs can be auto loaded when QtDragon starts by having the following in your INI file:
[DISPLAY] NGCGUI_PREAMBLE name_of_preamble.ngc NGCGUI_SUBFILE name_of_subfile.ngc NGCGUI_SUBFILE another_subfile.gcmc GCMC_INCLUDE_PATH ~/path_to/gcmc_lib
Jim
3 years 8 months ago #264360 by Roguish
Replied by Roguish on topic NCGGUI and QtDragon
thanks. I'll give it a try on a VM version first. don't want to accidentally mess up my working mill system.
3 years 8 months ago #264361 by Roguish
Chris. I can look into the source files.....
3 years 8 months ago #264369 by cmorley
Time to create page: 0.065 seconds
