qtvcp-hd versa probe crashes ui - solved
17 May 2023 03:27 - 17 May 2023 03:40 #271499 by grey_goat
Replied by grey_goat on topic qtvcp-hd versa probe crashes ui
I'm not sure if I'm having the same issue as I can't see what the original errors posted here are, but qtdragon crashes every time I click the probe tab too.
Last edit: 17 May 2023 03:40 by grey_goat.
17 May 2023 03:58 #271502 by cmorley
Replied by cmorley on topic qtvcp-hd versa probe crashes ui
run linuxcnc from a terminal, make it crash then post the terminal output here.
Depending on how you got linuxcnc, the changes might not have made it there yet.
18 May 2023 01:24 #271587 by grey_goat
Here you go.  Thanks for looking into it.
18 May 2023 02:59 #271590 by rodw
Replied by rodw on topic qtvcp-hd versa probe crashes ui
From what I can see you are running Bookworm. The last build of linuxcnc in it is back in about November. QTdragon/Versaprobe are still very new.
I think that has been fixed in later versions.
Now here is a secret short cut. Go here buildbot2.highlab.com/
Follow your nose via the debs here link until you get to the list of debs.
You should end up here
buildbot2.highlab.com/debian/dists/bookw...uspace/binary-amd64/
 Download the latest linuxcnc-uspace deb.
Currently this one but its an automated build system so it might change
linuxcnc-uspace_2.9.0~pre1.787.g913733ff1_amd64.deb
open a terminal in the downloads folder
1. Uninstall the current Linuxcnc  package
2. Install the deb you downloaded
sudo apt remove linuxcnc-uspace
sudo dpkg -i linuxcnc-dev_(tab)
21 May 2023 22:05 #271884 by grey_goat
That solved things. Thank you.
Time to create page: 0.103 seconds
