- Thank you received: 27
QTDragon operation
3 years 2 months ago #278588
by Vector
Replied by Vector on topic QTDragon operation
Quick update, I found the text for "bad characters" leads to the .po file /src/po/pt_BR.po
This tells us I'm creating the error in the [RS274NGC] section, as src\emc\rs274ngc\interp_read.cc is attempting to read that block in the .ini file.
First question: why does this line read:
Because the error "Bad character '0' used" seems to kinda point the 0 on that line.
In the .ini file. it's clearly a 0 (zero) not a O (letter o). (I even re-typed it by hand to be sure there wasn't some kind of invisible ASCII character in there, no luck.)
Second question: on the website linuxcnc.org/docs/devel/html/gui/qtdragon.html
the first line of the Subroutine_path = ends in a semicolon (
, should it end in a colon? (
like the next line?
And also, the default path for remap_lib seems to have changed: it no longer includes ngcgui_lib.
Sadly, changing/fixing/or breaking those lines in subroutine_path do not change the error message behavior.
I couldn't attach my on_abort or preferences file to the previous post, so I've attached them to this one.
Also, I made changes to the .ini to try and fix this, but since they don't fix it, I'm attaching the updated .ini file as well.
ON_ABORT_COMMAND=0 <on_abort> call
3 years 2 months ago #278589
by Vector
Doh!
So it is supposed to be an O (as in OMG) and not a 0 (as in, I'm a zero)... I clearly got it confused.
I've changed that around, and now that error message is gone.
Sorry for the text wasted.
My other problems with probing still exist. Should I repost that in: forum.linuxcnc.org/qtvcp/48995-qtdragon-probing-issues
3 years 2 months ago - 3 years 2 months ago #279361
by Vector
For future travelers: The documentation at the QtDragon screen was missing a parameter that needed to be set for the "travel to toolsetter" option to work.
To fix the "Probe Routine: Missing toolsetter setting: z_max_clear" error:
Under:
[VERSA_TOOLSETTER]
add:
Z_MAX_CLEAR = zzz
where zzz is the absolute z-coordinate for safe travel to the tool setter.
Under:
[VERSA_TOOLSETTER]
add:
Z_MAX_CLEAR = zzz
Last edit: 3 years 2 months ago by Vector.
3 years 2 months ago #279443
Replied by cmorley on topic QTDragon operation
pushed some fixes to the docs - thanks!
The following user(s) said Thank You: Vector
Time to create page: 0.266 seconds
