- Thank you received: 3
QTDragon operation
3 years 2 months ago #277083
by PedroSMS
Replied by PedroSMS on topic QTDragon operation
Thank you for your reply @rodw.
Sounds like it's going to be a painful process...
Not released - does that mean people are still working on issues?
Kind regards
Pedro
Kind regards
Pedro
3 years 2 months ago #277092
Replied by rodw on topic QTDragon operation
There are a handful of outstanding issues in 2.9 to be fixed before it is released. (About 6)
But the Debian policies mean that it can't go into the Bookworm repos when it is released.
Because QTdragon is pretty new, you need to be up to the minute as it does get changes pretty regularly as its tidied up.
So regardless, you need to install the custom repository that will allow you to install upgrades at any time by a couple of commands.
Its not hard. Put an hour or so aside and you'll get it done like many others who have followed the instructions I wrote in that link.
3 years 2 months ago #277097
by PedroSMS
Firstly, I will wait until it is officially released before I do anything.
Over the last few weeks, I have accumulated around 6 hours setting up the network config (plus other things) on this debian. I recon there's a 99.9% chance of debian losing that config with an upgrade.
My time maybe better spent on learning how to build it on OpenSUSE Leap...
Kind regards
Pedro
Kind regards
Pedro
3 years 2 months ago #277107
That might be trickier than you first think. Looks like you will need to compile the preempt-rt kernel as there is no package for it in Ubuntu.
3 years 2 months ago #277521
by Vector
Replied by Vector on topic QTDragon operation
I'm having an error and I'm suspecting it might be that QTDragon doesn't yet support 5 axis?
I had it working using pncconf, with 4 axis.
But when I manually changed my files to add in my extra axis (and I must admit, a joystick pendant), it always crashes.
Could be me, but the idea that it's limited to 4 has crept into my brain and now I'm hesitant to pour time on it.
In case that's not the problem, can you let us know it should work?
And whatever my problem is, if helpful, I've attached files.
"QTError.txt" is the error messages from the "pre-crash" screen that is working hard to help us with errors.
When I click "Retry" on that screen, I then get the full-on LinuxCNC errors screen. I clicked "Create Report File" and that is attached as "linuxcnc.report.txt" and "linuxcnc_info.txt"
My LinuxCNC version is: LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7
The screen looks very exciting! And I'm really eager to get a hold of a working probe gui... according to others on this thread (Rod, shout out), it looks like you might be positioning QTDragon to be the place for that on 2.9 and forward. If so, very much looking forward to it.
If not, then off-topic... is there a working probe screen anywhere on 2.9 atm?
Thanks again!
Thanks again!
3 years 2 months ago #277524
Vector, can you start Linuxcnc from the command prompt (linuxcnc -l opens the last config so I use that a lot but opening from the chooser works too)
Share the output as you get better error messages.
I'm not understanding why you are using an axis for a pendant though.
I have not tried for a while but I thought probing in qtdragon was pretty much fully working.
Time to create page: 0.260 seconds
