QTDragon stop & pause run
16 Sep 2023 00:30 #280895 by cmorley
Replied by cmorley on topic QTDragon stop & pause run
Shutdown_check must = True for preference saving to happen.
What are you actually trying to change?
Ya I forgot about keyboard pausing.
16 Sep 2023 03:02 #280900 by frayja2002
Replied by frayja2002 on topic QTDragon stop & pause run
I was trying to get rid of the annoying confirmation dialogue each time I exit LinuxCNC.
Is there another option for this?
Alex
16 Sep 2023 04:40 #280901 by cmorley
I guess I broke the behaviour a while back.
What you did was the right thing.
I have just fixed it - next update you can try it again.
16 Sep 2023 07:22 #280905 by frayja2002
I'd just like to say how much I appreciate all of your perseverance.
With all of you'r effort & willingness to help I can see one day QTDragon will be to go to interface for LinuxCNC.
Thanks again.
Alex
18 Sep 2023 05:42 #281042 by cmorley
Here is an update that allows using the pause key too.
The external pin  only can pause - would toggling on each true state be better or a separate external pin to unpause?
I was thinking maybe it would be better to have the pause button do regular motion pausing/unpausing and have the spindle pause button do motion pause, spindle pause and spindle lift.
That way you could do either - it may be more useful/intuitive for other people and if so could be incorporated into qtdragon as standard.
interesting request anyway - hope it improves your experience with linuxcnc!
Thank you for the kind words - QtDragon in linuxcnc is the combination of many people's work.
Jim the original creator has an even nicer looking version that i hope to soonish get started into master branch.
Chris
The following user(s) said Thank You: MarkoPolo
18 Sep 2023 16:28 #281095 by MarkoPolo
Replied by MarkoPolo on topic QTDragon stop & pause run
This now also works from the keyboard.
"..would be better to have the pause button do regular motion pausing/unpausing and have the spindle pause button do motion pause, spindle pause and spindle lift."
I think it's a very good idea, integrate with qtdragon and you could make this behavior an optional choice.
19 Sep 2023 09:23 #281143 by frayja2002
HI there
I have also tested it & it works as expected.
One small thing... If I hit the stop button the script runs ( to return to the home switches in my case) but if I hit ESC to abort it does not.
I don't know if this uses the same mechanism as pause but I thought I'd point it out.
Alex
19 Sep 2023 10:04 - 19 Sep 2023 10:16 #281147 by frayja2002
For the benefit of those who come after & myself in 6 months time her is a summary of things so far...
1) In your INI file add to the following sections
[DISPLAY]
USER_COMMAND_FILE = CONFIGFOLDER/pause_pin.py
[AXIS_Z]
OFFSET_AV_RATIO  = 0.2
2) In your custom_postgui.hal add
#Actually stop spindle whwen spinle pause is pressed
    net spindle-stop         qtdragon.spindle-inhibit             spindle.0.inhibit
# Set up Z axis external offsets
    net eoffset_clear       qtdragon.eoffset-clear                => axis.z.eoffset-clear
    net eoffset_count      qtdragon.eoffset-spindle-count   => axis.z.eoffset-counts
    net eoffset                 qtdragon.eoffset-value               <= axis.z.eoffset
setp     axis.z.eoffset-enable     1
setp     axis.z.eoffset-scale       1.0
# uncomment for dragon_hd
#    net limited                qtdragon.led-limits-tripped          <= motion.eoffset-limited
3) Download pause_pin_2023-09-18.py and save to your config folder as pause_pin.py
Set the "Spindle Raise" in the setting tab to a sensible value.
4) In qtdragon.pref
shutdown_check = True
Must remain as True in order to save "Spindle Raise" value.
If there's anything I have missed please let me know.
Alex
Last edit: 19 Sep 2023 10:16 by frayja2002.
The following user(s) said Thank You: rubes
31 May 2025 18:44 #329461 by Doc_emmet
Replied by Doc_emmet on topic QTDragon stop & pause run
Hello,
I can't seem to find the file pause_pin.py. Does the path have to be exactly "USER_COMMAND_FILE = CONFIGFOLDER/pause_pin.py" and does that mean my machine folder? Or where does the file have to be located?
01 Jun 2025 15:13 - 01 Jun 2025 15:14 #329513 by Doc_emmet
Hello,
I'm using the file pause_pin_2023-09-18.py and I'm getting an error message.
I started LinuxCNC in the terminal with "linuxcnc -v My-Machine.ini" and I get this message:
User command file for pause pin found
[QTvcp.QTVCP.QT_MAKEGUI][ERROR]  No module named 'qtdragon_handler' (qt_makegui.py:361)
  File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 359, in call_user_command_
    exec(compile(open(rcfile, "rb").read(), rcfile, 'exec'),local)
  File "pause_pin.py", line 5, in <module>
    import qtdragon_handler as SELF
ModuleNotFoundError: No module named 'qtdragon_handler'
How can I fix the error?
Last edit: 01 Jun 2025 15:14 by Doc_emmet.
Time to create page: 0.324 seconds
