QTdragon HD with MDI issue
2 years 5 months ago #300841 by cmorley
Replied by cmorley on topic QTdragon HD with MDI issue
Does it shutdown though?
The button calls this:
    def SHUT_SYSTEM_DOWN_PROMPT(self):         import subprocess         try:             try:                 subprocess.call('gnome-session-quit --power-off', shell=True)             except:                 try:                     subprocess.call('xfce4-session-logout', shell=True)                 except:                     try:                         subprocess.call('systemctl poweroff', shell=True)                     except:                         raise         except Exception as e:             LOG.warning("Couldn't shut system down: {}".format(e))
A fix for shutdown (I think) has been pushed to 2.9/master today.
One of the QtPlasmac (Greg) developers came up with.
Thanks for mentioning the problem.
2 years 5 months ago #301074 by vre
Replied by vre on topic QTdragon HD with MDI issue
The [ERROR] message is after pause button inside qtdragon.
2 years 5 months ago #301078 by tommylight
It does not seem to be from pause, it seems to be after 30 seconds due to a Usernmot module failing to communicate, probably the HY stuff.
2 years 5 months ago - 2 years 5 months ago #301089 by MarkoPolo
The error is caused by the fact that the pause button does not have any action selected in the designer, but this is nothing to worry about, although you could try to correct it..
edition
(the pause button is programmed in the handler file, it does not need an action selection in the designer)
Last edit: 2 years 5 months ago by MarkoPolo.
Time to create page: 0.078 seconds
