QTdragon HD with MDI issue
3 years 5 days ago - 3 years 5 days ago #283918 by cmorley
Replied by cmorley on topic QTdragon HD with MDI issue
I thought of this:
    def show_status(self, message, timeout=4):         if self.statusbar is not None:             try:                 messageid = self.statusbar.showMessage(message, timeout * 1000)             except:                 try:                     messageid = self.statusbar.setText(message)                 except Exception as e:                     log.verbose('Error adding msg to  statusbar:', exc_info=e)
Last edit: 3 years 5 days ago by cmorley.
3 years 5 days ago #283919 by snowgoer540
USRMOT: ERROR: command 30 timeout emcMotionInit: emcTrajInit failed
I'm told this is benign. It’s all part of the aforementioned code changes and will likely get sorted out in the not so distant future (hopefully).
Just ignore it for now.
The following user(s) said Thank You: whatawhiz
3 years 1 day ago #284154 by snowgoer540
I just pushed a commit that should take care of this race condition. Feel free to remove the sleeps you've added to the handler, etc. and give it a try. Let me know if you see any issues.
2 years 5 months ago #300295 by vre
Replied by vre on topic QTdragon HD with MDI issue
I have master with this error
Found file(REL): ./custom.hal Found file(REL): ./hy_vfd.hal USRMOT: ERROR: command 30 timeout emcMotionInit: emcTrajInit failed starttimer [QTvcp.QTDRAGON_HD_HANDLER][WARNING] qtdragon.eoffset-is-active not connected (qtdragon_hd_handler.py:570) [QTvcp.QTDRAGON_HD_HANDLER][WARNING] qtdragon.eoffset-clear not connected (qtdragon_hd_handler.py:570) [QTvcp.QTDRAGON_HD_HANDLER][WARNING] qtdragon.eoffset-spindle-count not connected (qtdragon_hd_handler.py:570) [QTvcp.QTDRAGON_HD_HANDLER][WARNING] qtdragon.eoffset-value not connected (qtdragon_hd_handler.py:570) No lower reesume eoffset state False /bin/sh: 1: gnome-session-quit: not found Shutting down and cleaning up LinuxCNC... Running HAL shutdown script
2 years 5 months ago #300313 by cmorley
Does the screen fail to load or is it just the messages?
2 years 5 months ago - 2 years 5 months ago #300317 by vre
It is just in messages screen loads ok.
This message is after press exit->shutdown
Last edit: 2 years 5 months ago by vre.
