- Thank you received: 90
This is a modification of qtdragon. Qtdragon_hd is in a different directory. If you really want, I can also modify qtdragon_hd.Meanwhile, run qtdragon (not qtdragon_hd) and check if this modification works.Hello,Using the qtdragon directory and your files
Yes. This is qtdragon , not qtdragon_hd.
If you want to change the appearance theme, press the F12 key.
Do tool images also appear in the tool table?
