z_level_compensation
2 years 4 months ago - 2 years 4 months ago #302136 by CADdy
Replied by CADdy on topic z_level_compensation
Hi Chris,
Where should the file z_level_compensation.py be located?
In my case there is only one file z_level_compensation under /usr/bin/ without the extension .py
Peter
Last edit: 2 years 4 months ago by CADdy.
2 years 4 months ago #302277 by cmorley
Replied by cmorley on topic z_level_compensation
yes I believe that is the one to replace, just remove the .py from the filename.
I'd keep a copy of the old file in case something goes wrong
2 years 4 months ago #302310 by CADdy
Hi Chris,
ok, I'll do it - thank you very much for your answer.
Peter
2 years 4 months ago #303775 by gardenweazel
Replied by gardenweazel on topic z_level_compensation
I just looked at this file on my host and noted that it appeared to be edited in DOS (ouch):  /usr/bin/z_level_compensation
There was a ^M on every line ending.
Cure and fix if you have this problem:  sudo  perl -pi -e 's/\r//g' /usr/bin/z_level_compensation
The following user(s) said Thank You: CADdy
2 years 4 months ago #303810 by cmorley
Thanks for reporting, I fixed it in the repo now.
2 years 4 months ago #303811 by CADdy
Thanks for the tip. I also had ^M on every line ending.
Peter
Time to create page: 0.076 seconds
