z_level_compensation
2 years 6 months ago #299124 by KlausB
Replied by KlausB on topic z_level_compensation
You are great - Thanks a lot.
I don't get the error any more.
The calculated offset is shown in the GUI (QtDragon_hd), depending on the position of the spindel.
But there mus be a nother mistake in my HAL file perhaps, because the offset has no affect to my Z-axis yet.
There is a indicator "EOFFSET LTD" should it be enabled?
I made two Screenshots, perhaps you have an idea whats wrong in my config.
File Name: Z-Compensation.hal
File Size:1.89 KB
2 years 6 months ago - 2 years 6 months ago #299169 by cmorley
Replied by cmorley on topic z_level_compensation
I am sorry for all the trouble - there is another bug.
I think I have it fixed - maybe you could test for me.
Put this file in YOUR_CONFIGURATION_FOLDER/qtvcp/screen/qtdragon_hd/
name the file qtdragon_hd_handler.py
If there is a problem your can remove the file and qtdragon_hd will load the default screen again.
Please stick with it - we will get this working.
Chris
Last edit: 2 years 6 months ago by cmorley.
2 years 6 months ago #299230 by KlausB
Hello Chris,
Thank you for the Info.
Of course, I’m happy to test that. However, it will take another day since I’m not at home this weekend. I’ll provide you with feedback as soon as I’ve tried it.
Klaus
2 years 6 months ago #299231 by cmorley
I'm afraid I may have given you an uncompatiple file. I based it on my 2.9 branch witch has other changes.
If it gives unrelated errors then bill have to find thecdoec8fic 2.9.2 version and fix it.
Not enough sleep makes mistakes!
2 years 6 months ago #299331 by KlausB
Hello Chris,
As announced, I tested the modified module today. The Z-axis is now moving. So far, I haven’t noticed any incompatibilities that might be due to a version conflict. Will you coordinate with Bill regarding the change? Will the modifications will be incorporated into a future update?
Thank you very much for your support and the work on this fantastic project.
Klaus
2 years 6 months ago #299339 by cmorley
Fantastic. I will incorporate the changes into 2.9.3. Thanks for sticking with it.
Please update in the future how you find the z level compensation works for you o your project.
Chris
Time to create page: 0.554 seconds
