Qtvcp GUI and hal pins
1 year 11 months ago #314174 by Levi
Qtvcp GUI and hal pins was created by Levi
Im not quite understanding how hal pins are associated with a gui button. if i look a qtdragon is there a simple way to look at say the estop and see what pins are directly associated with it? Or in axis there is axisui.jog.increment pin and i can use this to make my mpg work by outputting the scale but i don't see anything like this in qtdragon. Would this pin have to be added in the qtdragon handler file like the other qtdagon specific pins? In 12.5.4 Build A Simple Clean-sheet Custom Screen stops short of giving examples of the pins. The widigits look to hove some pins as part of them, is the manual the only way to see, how does this end come together?
Can anyone give me some direction, Thanks.p { line-height: 115%; margin-bottom: 0.25cm; background: transparent }
1 year 11 months ago #314224 by cmorley
Replied by cmorley on topic Qtvcp GUI and hal pins
Unfortunately I guess the short answer is no, there is not an easy way to see what pins the widgets create. I should try to add it to the docs I guess.
Qtdragon use the widget pins but also makes quite a few of it's own pins in the handler file.
A increments HAL pin would be a good pin to add to qtdragon.
Chris
1 year 11 months ago #314364 by cmorley
If you are using master branch - I added jog increment pins:
qtdragon.jog-linear-increment
qtdragon.jog-angular-increment
The following user(s) said Thank You: Roguish, tommylight, Levi
10 months 7 hours ago #340839 by jossen
Replied by jossen on topic Qtvcp GUI and hal pins
Hello Chris, i would really like the jog increment pins qtdragon.jog-linear-increment and qtdragon.jog-angular-increment. But i cannot find them, I'm running LinuxCNC 2.9.7. I have also searching through the master branch of QTDragon-HD, without luck.
How could I get the latest version of QTDragon-HD installed to my LinuxCNC?
Br. John
10 months 1 hour ago #340862 by cmorley
in your config folder there will be a set of folders: qtvcp/screens/qtdragon_hd/
in that last folder add the file 'qtdragon_hd_handler.py' that I have uploaded here.
It will give you the pins you asked for.
The developed version will be in master branch.
as for 2.9 - I think 2.9.8 was just released.
If you are using an installed version, it should be update-able.
6 months 1 week ago #345878 by COFHAL
Replied by COFHAL on topic Qtvcp GUI and hal pins
I've tried using qtdragon hal bridge function in every way possible, but it's not working. According to qtdragon documentation, if I understand correctly, if I define HALBRIDGE = hal_bridge
and also define a macro in the MDI_COMMAND_LIST in de INI file, qtdragon creates other pins that I can access through halbrdge , but these never appear in hal Show. I also understand that these pins related to the created macros can be accessed through external buttons, but unfortunately, there's no documentation on how to do this. In my configuration, I control some functions through external buttons connected to halbridge but for other functions, such as activating a macro, I can't, or I don't know how to, do it with halbridge.
Time to create page: 0.071 seconds
