Qtvcp GUI and hal pins
6 months 4 days ago #346013 by cmorley
Replied by cmorley on topic Qtvcp GUI and hal pins
How did you get linuxcnc originally? What version are you using?
What mods would you like to do?
The following user(s) said Thank You: COFHAL
6 months 3 days ago #346025 by COFHAL
Replied by COFHAL on topic Qtvcp GUI and hal pins
I'm using the latest available version of LNC 2.9. I regularly update my system, and the LNC version updates automatically. I initially installed it from the official ISO and also the DE.
6 months 2 days ago #346051 by cmorley
hmm linuxcnc 2,9 doesn't have the hal_bridge component nor a way to use it.
That may be why it wasn't working too :)
Could probably get it to work in 2.9, but it would take some experimenting.
6 months 2 days ago #346057 by COFHAL
with which version of LNC is it possible to use the hal_bridge component?
6 months 2 days ago #346060 by cmorley
The easiest is master branch aka 2.10.
5 months 4 weeks ago #346088 by COFHAL
Indeed, with Linuxcnc version 2.10, the HAL Bridge works and the Bridge pins now appear. Interestingly, in the QTDRAGON configuration examples, the macros and MDI-Command-macro are defined in the ini file, but the instruction HALBRIDGE=hal_bridge is not defined in [HAL]. It would be good to update the configuration to include it.
Time to create page: 0.062 seconds
