I can now call macros with external buttons, but unlike the buttons created and displayed on the main screen, which automatically switch QTDRAGON to MDI when clicked, with external buttons you have to manually switch to MDI for them to run. Another problem I'm having is that it can't execute macros defined as `O <XXXXXXXXX> call`. The status screen always shows "File not open," and the terminal debugs this error:
[QTvcp.QTVCP.WIDGETS.ACTION_BUTTON][DEBUG] INI MDI COMMAND #: 7 (action_button.py:717)
[QTvcp.QTVCP.QT_ACTION][DEBUG] COMMAND= O <touch_plate_z> call (qt_action.py:234)
[QTvcp.QTVCP.QT_ACTION][DEBUG] CALL_INI_MDI command:O <touch_plate_z> call (qt_action.py:249)
emc/task/emctask.cc 70: interp_error: File not open
File not open
The path where the macros are executed is defined in SUBROUTINE_PATHS= There are .ngc files to run those macros.
