Rotary axis in Qtdragon_hd
11 months 3 weeks ago - 11 months 3 weeks ago #337893 by deltafox24
 Hello, everyone! I'm writing here so as not to clutter up the forum with unnecessary topics.
I can't seem to properly configure the display of the rotation axis on QtDragon.
I tried setting GEOMETRY=AXYZ  and GEOMETRY=!AXYZ, and I changed both TRAJ and  KINS, but the rotation axis is still not displayed. For example, in this code there are 4 rotations of the A axis, but it draws like this
Last edit: 11 months 3 weeks ago by deltafox24.
11 months 3 weeks ago #337932 by cmorley
Replied by cmorley on topic Rotary axis in Qtdragon_hd
Can you post your config files?
11 months 3 weeks ago - 11 months 3 weeks ago #337941 by deltafox24
Yes, of course, here it is.
I removed it from there.
GEOMETRY = AXYZ
from there because it doesn't work for me anyway.
File Name: mycnc.ini
File Size:6.23 KB
11 months 3 weeks ago #338012 by deltafox24
Doesn't anyone use a rotary axis anymore, and does no one know what the problem might be?
11 months 3 weeks ago #338033 by cmorley
Do you want A to rotate around X?
if you load a tool and jog A is this what you see?
Can you test the simulated config?
11 months 3 weeks ago #338120 by deltafox24
When I load the tool, I see it rotating in the simulation, but all movement is drawn in only one plane. As I showed earlier
Time to create page: 0.109 seconds
