G-code file loading at G53 instead of G54
- CallumRD1
- Thank you received: 3
11 May 2025 19:38 #328216
by CallumRD1
Replied by CallumRD1 on topic G-code file loading at G53 instead of G54
Thank you so much! I figured it out with your comment.
It turns out that for whatever reason, when I set up my .ini file, I had commented out the .var file. I just uncommented it and now everything appears to be working normally. The offsets table is updating as I expect when changing work offset locations.
The littlest issues can be so frustrating when you don't know where to look, yet so easy to fix once you realize how the system works. Thank you again!
- Thank you received: 4149
13 May 2025 08:48 #328359
Replied by rodw on topic G-code file loading at G53 instead of G54
Great! You got it working! I was thinking maybe you had copied files from a CD or something so they could not be written to. But I was in the right area!
Time to create page: 0.498 seconds
