Problem with PROBE tab after running a program
12 Jul 2026 22:32 #347722 by cmorley
Ok here is the right file for 2.9 version.
As for the other error, set a probe tool number on the probe page - it defaults to black which won't be read correctly.
The following user(s) said Thank You: tommylight, RoberCNC
13 Jul 2026 06:42 #347730 by RoberCNC
Replied by RoberCNC on topic Problem with PROBE tab after running a program
It is Qtdragon_hd, that's right.
I will try along the day and feedback.
13 Jul 2026 10:15 #347733 by RoberCNC
Hi there.
When choosing the PROBE tab with the file in the indicated directory, a pop-up window comes with this error:
"Traceback (most recent call last):
File "/usr/share/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 626, in main_tab_changed
self.adjust_stacked_widgets(index)
File "/home/izan/linuxcnc/configs/QtDragon/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 126, in adjust_stacked_widgets
self.w.setCurrentIndex(num)
File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 493, in __getitem__
return getattr(self, item)
AttributeError: 'VCPWindow' object has no attribute 'dro_button_stack_4' "
(Attached the report)
In the other hand, I´ve set 99 tool number to probe, and after running a program if I go to TOOL tab, select it and push the M61 button to choose, it runs pretty good despite the down yellow line appears with the "cannot switch pages while in AUTO mode"
14 Jul 2026 06:17 #347756 by cmorley
well strange.
If you are content to just ignore the warning that's fine, otherwise I would need you to find the qtdragon_hd_handler.py file from your system so i could see why it's different.
14 Jul 2026 09:18 #347761 by RoberCNC
Hi Chris.
Here you have the file.
14 Jul 2026 15:38 #347768 by cmorley
Ok try this one:
15 Jul 2026 17:47 #347795 by RoberCNC
Hi Chris.
I´ve been using it for a while and this last archive works fine, everything seems to works properly, pretty good.
Thanks a lot.
16 Jul 2026 01:54 #347801 by cmorley
Glad we finally got it :)
The following user(s) said Thank You: RoberCNC
Time to create page: 1.137 seconds
