Problem with PROBE tab after running a program
3 months 2 weeks ago #347733 by RoberCNC
Hi there.
When choosing the PROBE tab with the file in the indicated directory, a pop-up window comes with this error:
"Traceback (most recent call last):
File "/usr/share/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 626, in main_tab_changed
self.adjust_stacked_widgets(index)
File "/home/izan/linuxcnc/configs/QtDragon/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 126, in adjust_stacked_widgets
self.w.setCurrentIndex(num)
File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 493, in __getitem__
return getattr(self, item)
AttributeError: 'VCPWindow' object has no attribute 'dro_button_stack_4' "
(Attached the report)
In the other hand, I´ve set 99 tool number to probe, and after running a program if I go to TOOL tab, select it and push the M61 button to choose, it runs pretty good despite the down yellow line appears with the "cannot switch pages while in AUTO mode"
3 months 2 weeks ago #347756 by cmorley
well strange.
If you are content to just ignore the warning that's fine, otherwise I would need you to find the qtdragon_hd_handler.py file from your system so i could see why it's different.
3 months 2 weeks ago #347761 by RoberCNC
Hi Chris.
Here you have the file.
3 months 2 weeks ago #347768 by cmorley
Ok try this one:
3 months 2 weeks ago #347795 by RoberCNC
Hi Chris.
I´ve been using it for a while and this last archive works fine, everything seems to works properly, pretty good.
Thanks a lot.
3 months 2 weeks ago #347801 by cmorley
Glad we finally got it :)
The following user(s) said Thank You: RoberCNC
Time to create page: 0.059 seconds
