Problem with PROBE tab after running a program
3 months 2 weeks ago #347715 by cmorley
Ok the fix was pretty simple and i have pushed it to 2.9 and master.
i don't know when a new release of 2.9 will be as there was just one done.
it is possible to add a customization to your current system to fix if you are interested or you can edit a file on your system to fix it.
The following user(s) said Thank You: RoberCNC
3 months 2 weeks ago #347717 by RoberCNC
Great!
Yes, I would be interested to fix it, if you would be so kindly to guide me on how to do it.
Thank you very much Crhis!
3 months 2 weeks ago - 3 months 2 weeks ago #347720 by cmorley
I assume you are using qtdragon_hd:
Ok in your config folder there should be a folder: qtvcp/screens/qtdragon_hd
In that folder add the file included here, name it qtdragon_hd_handler.py
Then run as normal.
If any thing goes wrong just remove or rename the file.
Chris
Last edit: 3 months 2 weeks ago by cmorley.
3 months 2 weeks ago #347721 by cmorley
hold on I did it for the wrong version of linuxcnc... stay tuned
3 months 2 weeks ago #347722 by cmorley
Ok here is the right file for 2.9 version.
As for the other error, set a probe tool number on the probe page - it defaults to black which won't be read correctly.
The following user(s) said Thank You: tommylight, RoberCNC
3 months 2 weeks ago #347730 by RoberCNC
It is Qtdragon_hd, that's right.
I will try along the day and feedback.
Time to create page: 0.076 seconds
