"Probe Height of the current tool" button not active in versatool
3 months 1 week ago #347888 by galmiklos
I use LinuxCNC 2.9.8, and trying to use versatool to do manual tool change with a tool length sensor and a touch probe.
I do this sequence.
1. Defined tool 99, and load it: M6 T99,
2. Get a pop up window about manual tool change, install the probe in the spindle and press OK,
3. Go to the TLS by pressing the first button in the first row (Go to Tool Setter),
4. Measure the probe height by pressing the second button in the first row (Probe Tool Setter Z Height),
5. Jog above my stock (aluminum), and measure its height by pressing the button in the middle row (Probe Z Height of material),
6. Load a tool: M6 T3,
7. Get the pop up, install the tool and pressed OK
I can see the PROBE HT and BLOCK HT variables set, as seen in the screen shot below.
I would then expect to measure the tool height by pressing the first button in the bottom row (Probe Height of the current tool). But I can't, it is not active.
What else do I have to do to be able to measure the tool height?
3 months 1 week ago #347928 by spicybagel
I don't use that workflow, but the button is also disabled in both my personal config that uses a tool setter and in the probing sim config. There may also be a separate issue even if the “Probe Height of Current Tool” button is enabled. The current BLOCK HT calculation uses the formula origin = float(INFO.INI.find("AXIS_Z", "MIN_LIMIT")) + value. Using the Z minimum limit doesn't really work or make any sense to begin with for me, but even if the machine was setup for that, the formula would only make sense if the probed value was a positive height measured upward from the Z minimum limit.
So doesn't directly answer why the button is disabled, but I can confirm it's not unique to your config and the routine in general is very confusing. Hopefully one of the developers who worked on these routines can clarify why the current BLOCK HT calculation does not produce the expected result and explain what setup or value the routine was originally designed around along with why the “Probe Height of Current Tool” button is disabled.
The following user(s) said Thank You: galmiklos
3 months 1 week ago #347938 by cmorley
The button is disabled because the routine is not tested enough.
last time we worked on it:
forum.linuxcnc.org/qtvcp/51138-qtdragonh...-maker-space?start=0
3 months 1 week ago #347944 by galmiklos
What is the workflow you use? I am not hooked on versaprobe. I wouldn't mind using any workflow to do manual tool change and work piece probing using a tool length sensor and touch probe. But I couldn't make anything work yet.
It was a lot easier to configure it with grblHAL. ;-)
3 months 1 week ago #347957 by cmorley
If you want to try it, I can give you the files to turn it on later tonight after work.
The following user(s) said Thank You: tommylight, galmiklos
3 months 1 week ago #347960 by spicybagel
I use the auto tool probe remap and it's very simple. I measure the distance of my tool setter from the machine bed, then put that value in for probe HT in the probe tab. Next I measure the distance of the stock top from the machine bed and put that value in for my g5x z offset. block HT is left at 0 no matter what, don't touch it. Now what happens when the auto tool probe remap runs is when you start your g-code, it brings spindle over to a defined change position, you change the tool manually to the one it's asking for, then it drives over to the tool setter location and creates a tool length offset. After it's done, your tool will be offset perfectly to where you programmed your wcs z0 in cam. I can explain more details about what's going on and why it's done like this if you want, but you're referencing everything off the machine bed which is absolute. Even if your on a router style machine and resurface your spoilboard, you just re-measure the probe HT value and you're back in action.
Time to create page: 0.079 seconds
