"Probe Height of the current tool" button not active in versatool
3 months 1 week ago #348021 by galmiklos
What is "the auto tool probe remap"? I mean I know what remap is in general, but it sounds like it is a name of something specific. Is it something one can download from somewhere? A quick googling didn't come back with anything specific.
In the meantime I studied the documentation and the source code a little bit, and I think I now have a clue what's what, and there are multiple ways to achieve tool offsets (G10 L2 vs. G10 L20 for instance). What I was looking for was a simple way and a sequence of click here, enter there kind of set of instructions.
I eventually managed to make the standard tool touchup work. The one where you enter the the tool height in the settings tab, enter the workpiece height in the offsets panel on the main screen, and you just click on the tool sensor button, which will calculate the Z value for the current WCS and sets it with G10 L20 (after touching the sensor with the loaded tool).
3 months 1 week ago #348038 by spicybagel
Yep, that's it. Should be in ~/linuxcnc/nc_files/examples/remap-subroutines on your actual pc. Just know that it's changing the tool length offset (tool table Z) instead of the actual WCS Z offset. So you put the height of your tool setter above the machine bed in "probe HT" of the probe tab (leave "block HT" at 0 as mentioned before). Then you put the height of your workpiece above the machine bed in for your desired WCS Z offset.
So example would be the toolsetter is 1 in above the machine bed and your stock top is 3 in above the machine bed. You set "probe HT" to 1 and your G5x Z offset to +3. You have to turn on the "tool measure" button in the probe tab and now when you run your program, the remap automatically takes over once the M6 line is reached and it will bring the spindle to your defined change position in your .ini, then after you change the tool and hit OK, it will drive over to the defined tool setter position in your .ini and probe the tool which will automatically fill in the tool length offset in the tool tab. Same diagram as figure 7 in section 14 of qtdragon docs, but "block height" is your g5x z offset. If you want to run without the remap, just turn off the "tool measure" button in the probe tab. It will still bring the spindle to the change position, but doesn't probe the tool and doesn't create a tool length offset. Nice thing about running the remap this way is it creates a universal tool measurement independent of the part setup allowing you to run multiple WCS offsets at once.
You need to make sure your .ini has all the things shown in section 14.3.2 of the qt dragon docs for this to work. it's also very important to make sure you are using the qt_auto_probe_tool.ngc file from 2.9 and not the 2.10 master branch as the 2.10 version is different formula and won't work the same. Included my .ini, .hal, and personally modified .ngc remap if you want an example of what it looks like.
Time to create page: 0.248 seconds
